PCS Power Vision works via USB, but not full speed on BT
  • PCS Power Vision works via USB, but not full speed on BT
    My A900 works perfectly in PCS Power Vision mode through a USB connection. I get amazing speeds (up to 1.5mbits) and the icon on the phone indicates that it's using the Power Vision connection.
    However, when I connect through my Bluetooth dongle, it only uses PCS Vision at around 200kbits.. and the icon on the phone indicates it as such.
    I hope this make sense.
    Anything I'm doing wrong?
    Bluetooth is slower than USB...
    It's almost like when you plug in an 802.11G USB 2.0 Wifi Dongle into a USB 1.1 USB port...
    The fastest you will go is 11mbps...
    Post # 3000
      I have an A900 as well. I heard that the A900's have problems with bluetooth. How has yours been working?
      2003 Nissan Xterra Worklog
      Total amount spent so far: $1196.64
      You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
      2003 Nissan Xterra - Modifications
        My A900M has worked great via USB or via bluetooth.
        1998 Volvo S70 T5: Nothing much yet, 7" Lilliput molded into the dash and a MicronPC laptop on the passenger seat :)
          I don't have that phone or Sprint but even though bluetooth will be slower than USB, you should be able to get faster than 200kbps... I dialup through bluetooth using my LG phone on cingular's 3G network and can usually get up to 500-600kbps over bluetooth and of course faster using USB.
          '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
          2006 Chevy Equinox LS (Current Project)
          **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
