Hardware Review: Lilliput 669GL-70NP/C/T 7" HDMI Monitor
  • Hardware Review: Lilliput 669GL-70NP/C/T 7" HDMI Monitor
    What is it?
    The Lilliput 669GL is a brand new 7” touchscreen monitor featuring HDMI connectivity.
    The Verdict:
    When weighing the new features with some of the things still missing in a 2010 Lilliput model, its clear to see that the 669GL is the first model in what many hope will be the future of small touchscreen monitors. Lilliput obviously spent time and focus on getting HDMI/DVI capabilities to work, and they DO work. This is the clearest Lilliput display out there, as long as you are not working in the sun.
    See the Lilliput 669GL on the mp3Car Store here.
    What’s in the box?
    The Lilliput 669GL comes packed with practically every kind of cable you would need to use with the monitor. Included is an HDMI to HDMI-USB cable, HDMI to DVI-USB cable, VGA to VGA-USB cable, and a DIN to composite (2 input) cable. For power, the 669GL comes with both a home A/C adapter plug and a 12v DC car charger cable. The 669GL also comes with a standard VESA mount, remote control with battery, touchscreen driver CD, and instruction manual.
    Description:
    The 669GL-70NP/C/T is the latest 7” touchscreen monitor Lilliput has released. To my knowledge it is the first 7” monitor of its kind to feature on-board HDMI connection. The creators were wise to leave compatibility with the tried and true VGA connection, and even threw a HDMI to DVI cable to further enhance compatibility. Regardless of your preferred input source, the Lilliput 669 has you covered.
    Though it makes hardly any difference when connecting to 669GL to a standard computer, car PC enthusiast should find the HDMI connection a lifesaver when it comes to getting a monitor installed in a vehicle. This is of course is provided they have the motherboard and/or video card that accepts either an HDMI or DVI connector. Prior models of Lilliput and other small monitors in the car PC community have suffered from screen ghosting and/or flickering as a result of having to run long strands of analog cabling inside a motor vehicle where interference issues tend to be more prevalent. I made it a point to test this issue with a full-digital HDMI connection. My aging Lilliput 629 installed in the dash of my RSX has always had some level of flickering and the ghosting of images and text is just something I grew to live with. I’m happy to say that the connecting the HDMI from my Intel DG45FC motherboard directly to the Lilliput 669 immediately solved BOTH problems.
    I also noticed shortly after powering up the PC that the colors on the screen just appear deeper than with previous Lilliput screens. I don’t know if it’s the digital connection or perhaps the new LCD panel installed in the 669GL, but the color and contrast is among the best I’ve seen on a 7” screen. Text appears sharper than before, even in the 1024x768 photos shown above. With an HDMI connection the screen is fully capable with 1080i/p playback, a feat that's extremely impressive for a rather small screen.The Lilliput 669GL features an all new bezel, new LCD panel (Innolux AT070TN82), and a new, slightly larger controller board. This of course means someone wanting to upgrade from an older lilliput may find complications in there existing fabrication when switching to the 669GL. The HDMI sticks out more than the previous VGA cable. This coupled with the larger controller board means the 669GL is not easily compatible with enclosures such as the double-din enclosure that MP3car store sells. I was able to just barely make the enclosure work by using a right-angle HDMI adapter and alternate means of securing the controller board to the enclosure.
    The main problem you encounter with the 669GL occurs when you place this monitor into direct sunlight. For some unknown reason, the manufacturer decided to scale back the brightness on the 669GL. The rating in the monitor’s specification is just 250 nits. If there were one absolute bummer when it comes to the 669GL it’s that its just not meant to be used sunlight. The colors completely wash out, and because the screen is not transflective you must deal with a tremendous amount of glare before even beginning to interpret what’s on screen. Below are two comparison photos; the first is with no flash taken with my digital camera, the second with flash and a rather low ISO.
    Unfortunately, the brightness on the LCD isn’t the only thing missing from the Lilliput 669GL. It does not currently have the ability to automatically switch to an auxiliary input upon connection of a 12v source. This means us with rear-view cameras must come up with another plan to see what we’re backing up into. Prior model Lilliputs like the 629 had the ability to modify the controller panel to accommodate this feature but to this point it’s not possible to do on the 669GL.One feature that’s missing that perhaps will not affect car PC users is the lack of backlit buttons on the front of the enclosure. To my knowledge this is the first Lilliput that has had this missing. The power button lights up, barely, but the other buttons remain in the dark.The last feature that didn’t make the cut is the ability to control the screens brightness via a photosensor on the enclosure. At first glance it appears the IR receiver on the front of the Lilliput bezel has been modified to accommodate this in the same manner than competing Xenarc and other devices do, but in testing I see no difference in screen brightness between light and dark rooms.
    The Positive:
    • HDMI connectivity
    • Abundance of wiring options
    • Cleaner display with rich color and better contrast
    • Native resolution of 800x480, with the ability to display 1080p
    • Auto-power on when video signal is detected
    • Priced well to compete with other manufacturers
    The Negative:
    • Lower brightness rating than competing products
    • No auto-switch capability
    • No auto-dimmer found in competing products
    • STILL no transflective!
    • New controller board means incompatility with some bezels on the market
    The Verdict:
    Live mp3Car Facebook Chat
