New MJS USB IO-1 4 Relay & 4 Input Device
  • New MJS USB IO-1 4 Relay & 4 Input Device
    MJS Gadgets presents their newest USB IO device. Combining 4 digital inputs and 4 relays, it's perfect for powering on and off amplifiers, ambient LED lighting, raising a power antenna, or anything else than requires a intelligent power switching.
    Features
    USB controlled and powered.
    This interface is USB for PC control. HID device no drivers needed.
    4 Relays (1 amp) selectable Normally-Open or Normally-Closed
    4 Digital Inputs (5 30 volt opto-coupled).
    Plug-able Terminal Blocks, (Phoenix style).
    Car PC: Ride Runner support.
    Car PC: Centrafuse support.
    Includes USB A to mini-B cable.
    FREE Developer .NET/Com Object Control Class. (Available in the Developer forum.)
    Package Contents
    USB IO Controller
    USB to mini cable
    DVD
    SHOP NOW
    Have a product you would like to sell on the mp3Car Store? PM me for more information.
    Have a car computer question? Ask me by emailing the store.
    Both RideRunner and Centrafuse plug-ins are updated... download from my skydrive
    http://cid-ed9324dabf9c9cb3.office.l...se.aspx/Public
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      okay so quick question, could I use this to power on my amp AFTER my computer completely boots up in an automated and easy(as in I'm not a programmer!) way?
      I have a feeling that the answer is yes, i just hope its easy enough to implement!
        yes, if you use Ride Runner or Centrafuse....
        if you dont, then you prob will have to code it yourself, (or ask me to do it)
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          So to switch on say an AMP with this device, i dont need to draw 12V from the battery and those massive current of amperes?
          For my carpc project ive used 3 relays for various tasks
          [1] Power switch for carpc PSU
          [2] Turn on AMP (remote trigger via DSATX)
          [3] Trigger reverse on the Lilliput 629
          and I'm using those huge 30A one cause i figured i need the amperes - is this not then the case and I could use this device?
          New Car PC Build list in progress
            you definitely dont need anything more than this device for the remote wire that actually turns on the amp. that line typically only runs a few mA as its nothing more than a signal to the amp to use the larger power wire to turn on.
            Live mp3Car Facebook Chat
              Im actually looking for a board of relays but would like them capable of providing 30A as don't want these huge units.
              OK, so I can trigger my amp, so i assume i could also trigger the lilliput to switch when in reverse, thats 2 down, but i would need to keep the carpc trigger as this supplied the DSATX PSU
              Now the only problem is i only have 10 USB ports and don't want to add a hub..
              My USB ports that are used for are
              [1] Touch Screen
              [2] GPS
              [3] BT phone
              [4] BT keyboard
              [5] TPMS
              [6] DAB+
              [7] ECU Dongle
              [8] Wireless LAN Dongle
              [9] 3G Data Card
              [10] reserved for video capture device
                [1] Touch Screen
                [2] GPS
                [3] BT phone
                [4] BT keyboard
                [5] TPMS
                [6] DAB+
                [7] ECU Dongle
                [9] 3G Data Card
                Isn't the Lilliput's reverse trigger a ground/voltage wire anyway? What ever you use to trigger this device could go direct to the Lilli, couldn't it? Unless there's something else you want to trigger when you go into reverse, you'd just be wasting an input/output on this.
                VegasGuy
                  i have problem when triggering this so i want to test this again with a relay or diode as when i release the trigger it reverts back to VGA but then turns off the screen.
                  Digressing a little but my 629 wasn't designed for reverse, it's been hacked and work in progress
                  Cheers
                    Cheers
                    Ah so, I understand. Hardware hacks are ALWAYS an adventure. Enjoy!
                    VegasGuy
                      Just got mine in the mail a couple days ago and hooked it up tonight. So far everything is good and working as described in the documentation. I've tested all the relays using the test program and they all work. My questions are more about the inputs, do the inputs trigger relays too, or are the inputs more used for indicators in RR? Going to go review the code, just thought I would get it out there. I understand how to hook it up, just wanted a bit more detail on the functions and uses of the inputs.
                      -Joe
