Car Computer Install: Wiring The Amplifier Overview
  • Car Computer Install: Wiring The Amplifier Overview
    Embed this video
    Sean Clark, from mp3Car, shows us how to connect the amplifier in your vehicle, an essential component to any car computer install. The 12 volt positive power cable is wired directly to the positive terminal on the battery, with a fuse in line as close to the battery as possible. The negative wire is also run directly to the battery to prevent noise from being introduced into the system. The ACC wire and the speaker wires are connected to the factory wiring harness using an adapter made specifically for this vehicle purchased on the web.
    Have a product you would like to sell on the mp3Car Store? PM me for more information.
    Have a car computer question? Ask me by emailing the store.
    did you happen to get your wire gauge sizes mixed up while talking? i can see that your ground distrobution block wire is larger then the wire feeding the amp, but you said that the positive amp wire is 8ga, and the one coming off the distro block is 10ga-- which is smaller in diameter then 8ga... while it is typically recommended to run a larger diameter ground back to the battery, at a minimum, run the same gauge wire for both power and ground..
    hopefully you straightened out that ground attachment at the battery-- that is putting un-needed stress on the cable to loop it out the top like that.
    it is typically recommended to use different color wiring for the power and ground-- esp when running the length of the car, so that they don't get confused later on.
    every vehicle is 'supposed' to have a 12v accessory wire. with the advent of canbus, some cars no longer have a specific wire in the radio harness that has this(the radio is turned on by a 'on' command sent over the canbus). there should still be a wire in the fuse box that is switched with the ignition, but it can take some time with a volt meter to locate..
    when you zoomed real close to the wire-- is that solid-core wire?
    in terms of connection, i am still a advocate of using rca y-adapters off a single 3.5mm jack to feed all 4 speakers-- it is the only method that is guaranteed to work regardless of the motherboard drivers(some don't support the 'enable rear fill' option that is needed for the method in the video to work)..
    next project? subaru brz
    carpc undecided
      Yea I did mess up the guage. The blue wire is 8gauge throughout. We wanted to use the brown 10 gauge for ground, but simply didn't have enough. Since every amp kit we looked at only gave us a few feet of brown cable. So we uses more blue 8 gauge for ground back to the battery. Which is straight now. We just pulled them to make it visible.
      It's not solid core wire, its got 4 wires spiraled together.
      So you would go 2 Y splitters and 2 3.5mm cables into the computer?
        ah, i see..
        not the overall construction, but the construction of each individual wire--
        does it look like this:
        http://www.computercablestore.com/10...S_PID2286.aspx
        which is solid core-- there is only one copper conductor for each wire
        or this
        http://www.computercablestore.com/10...a_PID2093.aspx
        which is stranded-- there are multiple strands of copper for each wire
        only 1-3.5mm cable:
        while this looses balance, and fade control at the carpc, it is something that will work regardless of the hardware used. too many times, certain hardware won't work the way that yours is setup-- granted, there are many boards that support the same feature, but isn't it typical for people new to something to 'just happen' to pick one of the very few options that don't work like what everyone else uses(seems to be my luck anyways)?!?
        carpc undecided
          I had to do the same thing as you soundman, whenever playing audio files only the front speakers would work, the only time I had audio on the rear was during DVD playback 5.1 channel. So the best solution for my set-up was the splitter. Also when hooking up a separate amp for the subwoofer the 3.5 jack was paired with the center channel so I needed another splitter at the subwoofer amp for the L/R channels.
          Also a quick comment for the Ground wire, I understand the theory behind what you did, however it is very redundant. There should be a good ground point near your amp and if not you can make one. Seems like a waste of wire.
          MY INSTAllS:
          http://www.mp3car.com/vbulletin/show...e-install.html
          http://www.mp3car.com/vbulletin/show...tallation.html
            I noticed something funny. On your other video you ran the power down one side of the car, then the audio down the other, but now you have wrapped them all together at the end. So wasnt seperating it a waste of time?
            Also, as far as soundcards, it depends on the card. Thats why I refused to trash my PCI Soundblaster XtremerGamer card. It had an option to push audio through all speakers if it was only stereo, which normally only plays through the front 2 speakers. Thankfully I found a PCI to PCIe converter, so I was able to use on my new Mobo, which didnt have a PCI slot.
            1X Ainol Novo Flame Tab
            4X MK808b
            3x Perixx Touchpads
            3x 7 inch Screens
            1X 7 inch motorized Screen
            1x Win 7 PC
              i actually never had that problem, but have come across it way too much to not bring it up--it seems less these days, but when i first started, i remember tons of posts/threads about the issue. the whole reason for my carpc is audio processing, so i was past any issue like this from the beginning
              no, that is mostly recommended way. the idea here is to keep the power and audio cables separated for as long as possible. when the cables get run together for long distances, that is when it increases the chance of noise transmitting between the cables. to keep the cables together for a couple feet rarely causes any issues..
              of course, it would be preferred to keep them separated for the entire length, but in most cases, it just isn't practical to do so.. like in the case of your install
              this is as clean as i could get my own install-- and it takes up much more space then most installs:
              carpc undecided
                Awww, thats cute. Mine will never look like that, lol.... I did notice something I did. I ran speaker wire down the sides of the car, and all other cables run down the middle. I did this on accident though.
                What are those 4 small boxes in the middle of the wire covers?
                4X MK808b
                3x Perixx Touchpads
                3x 7 inch Screens
                1x Win 7 PC
                  my 4 cl-rlc preamps
                  i'm still not happy about the way those tubes look, but you have no idea what kind of mess hides below those things.. the tackyness of the tubes is actually a improvement..
                  carpc undecided
                    Need some help... Please
                    I have started building the same system as here. I have the computer all together and did the bench test but it is not wanting to boot. I have it hooked up to a cigarette lighter for power and have both the red and white wires hooked up to positive, and the black to the negative. I then took it all back a part verified all of my steps and connections, and tried it again and still it will not boot. The only thing I can see that happens isthe case fans start, the cpu fan starts, two green LEDS light up on the motherboard. I have no keyboard, and nothing on the monitor. Also when I tried to use the button it did not shut off, and sure if it should either.
                    I tried hooking it up to the power supply on my desktop and the same thing happened.
                    I welcome any suggestions that I can try to trouble shooting to figure out where I went wrong.
                    JM
                      are you testing the entire carpc with the desktop power supply, or you took it apart and tested the motherboard--bypassing the car-compatible power supply?
                      the first plan of attack is to always check the connectors, and also re-seat your memory--that is usually the most common cause of the issue.
                      carpc undecided
                        Thanks for the reply!
                        The first try was the same way that was shown in the video with cover on etc. then took the cover off, checked connections etc. Then disconnected car pc power supply from the MB then connected the power from my desktop PS and got the same results.
                        I was reading on the MB site that they said the memory is usually what is causing the problems just as you did. So I did try that last night as well with no luck.
                        So I am guessing that the first thing to replace is a stick of RAM since the minimal things I need to have a POST is PSU (obviously), CPU, at least 1 stick RAM, and Video Card.
                        I guess I can hook up a speaker to see if I am getting any beeps out of it....
                        Thanks again for the help. Greatly appreciated!
                          A bios beep doesn't require external speakers (usually) - most motherboards have a tiny onboard speaker just for that purpose.
                          1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
                            it seems more and more boards are making it a add-on-- where there is a header for it, and no speaker is built into the board..
                            the easiest way to test this is to boot without the ram-- assuming the board is not completely fried, and the speaker is on it, it should start beeping at you because there isn't any ram installed..
                            and if that first test went ok, if you have extra ram to try, that is a good first step. otherwise, if you have a pc repair shop/parts store nearby, they are usually ok with loaning some ram for you to test with-- just be sure to take the whole system in there so that it is easier to test(they usually don't like the ram to leave the building).
                            carpc undecided
                              I seen the 4 pin header.
                              That's actually a good idea to take it in to a shop, but the ones here in phx seem to charge just to use their door...I am going to run to the store and pick up a stick. My brother-in-law is wanting to build one too. So it won't be a waste.
                              Thanks for all the comments, ill report back when I give it a try.
