Results 1 to 8 of 8
Thread: VOLUME_ double clicking button, volume fades to 0 or 100%
    Maximum Bitrate Maņana's Avatar
    Jul 2004
    Sweden
    When doubble klicking one of the volume buttons in fullscreenmode the volume fades to 0 or 100% (depending on whitch button you doubble klicked).
    This is quite irritateing while driveing on bumpy rodes, and you want to raise the volume a little, and then it goes up to maximum...
    Jan 2003
    Ruston, LA
    Quote Originally Posted by Maņana
    While there may very well be a bug there, why are you double clicking ?
    It is a click and hold button.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Yeah I found the same thing in the main screen if you double click anywhere, including the volume button it brings up the jump mode. I just make the percent that the volume is increased higher for one click so I wouldnt have to double click it.
    肚子笑痛了
    S60 Install
    Jul 2004
    Sweden
    Quote Originally Posted by frodobaggins
    I don't mean to. It happens nearly always when im driving on bumpy roads, or at high speeds. You let go of the ts for like 1/10 of a second, and then it starts turning up the volume...
    Jul 2004
    Sweden
    The most confuseing thing is that it doesnt happen when in normal mode, just in fullscreen :S
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    I've seen it happen in both modes. Thought it was click and hold to slowly go up/down or double-click to quickly go up/down and won't stop until double-clicking again. Was actually gonna ask if there could be a way that we could disable that 'feature'.
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
    Jul 2004
    Sweden
    And often, if I miss a button and just klick at an empty space of the skin, that brings up the on screen keyboard. (useing febīs metal skin) But i think i had that problem with the original skin too... Gonna check when i get home...
    Jan 2003
    Ruston, LA
    That is supposed to happen. That's the shortcut to jump mode.
    If you double click any unused area, it brings up jump mode.
    You can disable it in the settings. (But if you do, and want to
    use jump mode, you'll have to add the jump button to the skin)
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
