Please post everything the Microsoft error box gave you.
Bug: If a DVD is playing and I power down the laptop I get an error and FP hangs requiring hard reboot
Error: Microsoft error box says VOLUP failed
System: Windows XP Pro SP2 WMP10 and all other updates; FP take 3; WinDVD 6.0 (for DVD codec); AC3Filter ver 0.70b
Misc: The last thing I did to CarPuter is turn the volume up when playing a DVD...
happened 3 times in a row getting in and out of truck out shopping..
CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
Display: Lilliput 7" TouchScreen
CarPuter Install
[H]4 Life
I'm a lesbian too.
I am for hire!
Um... can't do that now. I'll get that info tomorrow... it's 34 degrees out there!![]()
But it was the standard M$ error window... that was the command in the title line.
Thanks for the quick reply... good eats!
CarPuter Install
Sorry for not getting the info back to you sooner...
Microsoft error box says:
_________________________________________________
End Program -- VolUP
Program not responding
Return to windows & check the status of the program
The system is hung up and will not respond... have to do the 4 second
hold of the power button to hard reboot.
And it is the last button you push... because I tried turning the volume down on DVD
and then shutting off and that was the error I got then (volDOWN)...
If I press the stop button on the DVD it shuts down fine.
I'm using Feb's skin if that would matter...
Thanks!![]()
CarPuter Install
