I am using Synchronize on a 800x600 resolution with no problems at all... are you sure you are not in 640X480 for some reason ??
here is a screenshot of me using synchronize:
Synchronize is not scaled small enough for the display and, although I can scroll to the right on the initial screen, the scrollbar does NOT work on the job setup screen so I can't get to the exit button. The "about" screen is the same way and I can't exit from it.
Nope, definately in 800x600 using Febs skins. The skins are all ok but here's my synchronize screen. It evidently knows it's bigger than the display because mine has a scrollbar and yours doesn't.
Three questions remain from all this:
1) Why is strohs screenshot so different from mine with both at 800x600?
2) Why does the scrollbar not work on the job edit screen?
3) Is there any way to setup sync jobs outside of FP?
Have you messed with windows fonts ? Are you sure youOriginally Posted by wysocki
are running at 800x600?
Bug.2) Why does the scrollbar not work on the job edit screen?
[/QUOTE]3) Is there any way to setup sync jobs outside of FP?
No, at least not currently.
[H]4 Life
I'm a lesbian too.
I am for hire!
Well, I had NOT changed any of the fonts in the display/appearance section for specific items. However, after searching through the settings, I DID find that I had set the display|setttings|advanced|Font Size to "large fonts".Have you messed with windows fonts ?![]()
I had evidently done this early in the setup of this pc on my 7" Xenarc because it is so TINY next to my 21" desktop display. In fact, I'll now have to go through the skin settings and kick the font sizes up because I can't read them while on the road.
I'm puzzled though why the non-font items on SOME of the screens (xm, gps and sync specifically) were magnified as well???
