Results 1 to 9 of 9
Thread: MINI MODE_when returning to normal mode
    Maximum Bitrate Maņana's Avatar
    Jul 2004
    Sweden
    Exclamation MINI MODE_when returning to normal mode
    When in minimode, and doubble klicking the five small dots to return to normal mode, FP returns for about 1/100 second and then goes back to minimode. I't works correct in 1 of 20 tries.
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    have you tried to adjust your double click settings, sounds llike your clicking too many times. Works perfect for me. Try to change your double click rate and see if it still happens.
    Jul 2004
    Sweden
    Yes, if i set the doubbleclick speed to the slowest, it will work when I doubble click at normal speed, but if i click slow, I get the same problem.
    As a matter of fact I figured out that with normal doubbleclick settings I have to click fast as he** to get it work.
    Frodo seams to require a very fast doubbleclicking?
    Jan 2003
    Ruston, LA
    Quote Originally Posted by Maņana
    FrodoPlayer uses the same double click rate as the OS.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Low Bitrate djtrickee's Avatar
    Aug 2003
    Denver, CO
    Agreed. I wish there was a way to change the .INI or something to use the 1 sec hold or 2 sec hold to return to normal and not the double click method. Its very frustrating while driving to have to try and double click on a touchscreen monitor. Nothing should be double click!!!!
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Something must be up with your touchscreen driver, because I can double click minimode at any speed and it comes back just fine. What LCD are you using?
    肚子笑痛了
    S60 Install
    Aug 2003
    Denver, CO
    Stupid Lilliput. I HATE it. But other than that it works fine, and the touch works fine on it (so far ^^crosses fingers) I have windows set to 1 click browsing. So i dont have to double click on desktop icons and such. This of course doesnt work with Frodoplayer.
    Jul 2004
    Sweden
    Quote Originally Posted by jcdillin
    I'm not useing any touchscreen, I'm trying fp out on my home Comp. Gooing to look in the ini file...
    Jul 2004
    Sweden
    Can't find anything wrong?
    Since I don't use minimode it doesn't bather me especially, just reported it.
    And since noone else had this problem it's probably just my Computer ******* around... =)
  1. Mini Mode Shortcut
    By frodobaggins in forum FP FAQ
    Last Post: 12-01-2004, 05:52 PM
  2. Frodoplayer Mini Mode Tranparency
    By wkolodny in forum FrodoPlayer
    Last Post: 10-25-2004, 02:58 PM
  3. can you move the mini mode buttons
    By nappyjim in forum FrodoPlayer
    Last Post: 10-23-2004, 02:11 PM
  4. Replies: 9
    Last Post: 09-22-2004, 10:46 PM
