I'll take a look.
My pc crashes when I boot and I go directly to the FM Radio player.
On the crash it immediately reboots the pc...
The pc rebooted 3 times in a row until I finally got it to play the radio
by first playing an MP3 for just a few seconds then going to FM mode.
It then loaded and worked fine. Tested this twice and worked both times.
I was in the Directory (1) mode when I did this.
Win XP Pro sp2; Frodo take 3; Feb's metal skin; Radiator; D-Link usb radio
CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
Display: Lilliput 7" TouchScreen
CarPuter Install
I'll take a look.
[H]4 Life
I'm a lesbian too.
I am for hire!
do you have your pc set to auto reboot when it bluescreens? If so, can you turn it off to get any info in the bluescreen, maybe it can help pin point the reason it crashed.
Yea I do have it set to auto-reboot... hmm... I'll do that and see if any pertinent info..
Thanks... good idea![]()
CarPuter Install
also check in control panel that its got the right drivers loaded (from the radiator website) then make sure the radio works in radiator before using your "player"
Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
FS = MTSVO motorised in dash screen pm me for details
Yea.. radiator has the right drivers loaded... has always worked with radiator and with frodo, media engine, etc...
I just knew it would crash occasionally... just today I actually figured out the sequence of events that was killing it....
Never really use radio... just was out when the Steelers were on and wanted to hear every juicy minute![]()
CarPuter Install
