Results 1 to 10 of 10
Thread: KEYBOARD_ shortcuts not working intermittantly
    Perth, wesatern Australia
    Exclamation KEYBOARD_ shortcuts not working intermittantly
    As the title suggests.
    Usually happens as I enter Fullscreen mode (which works fine from keyboard), then exit it. It seams that after that point none of the shortcuts work.
    If I click on a song in the playlist the shortcuts then work fine.
    Any ideas?
    Im using the following.
    Latest Frodoplayer 1.0.9
    cirque serial touchpad
    old digital ps2 keyboard (for testing)
    usb belkin nostromo n50 keypad
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    What's your VIS? Soem VIS end up having focus after doing just that.
    Jan 2003
    Ruston, LA
    Well if they are "not working intermittenly" then I guess it's working properly
    No ideas. But will look.
    And also, do not use the "BUG" Icon on your posts. They correct procedure is
    outlined in the stickeys at the top. In this forum, the "BUG" icon is for my own
    personal use only.
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    ok frodo, will remember for next time.
    Im using the Gforce vis (tis very cool).
    is there any way to set frodoplayer's shortcuts to be global?
    EDIT: tried with a different plugin, seams to work fine. Anyway to get around this? I really like the Gforce plugin.
    Jan 2003
    Ruston, LA
    Quote Originally Posted by cnidus
    Not in this version.
    However you could always use girder and the keyboard plugin.
    A sample GML file is in the main FrodoPlayer forum.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jul 2004
    Berkeley, CA
    Yeh, actually gforce was the vis I was talking about. So yeh, gforce will capture the keys. It was annoying. I jsut ened up disabling all frodo keys
    well as cartman says "GODDAMNIT".
    0l33l, got any other suggestions for visualisations? (PM them to me, dont want to clog up this forum)
    Cheers guys,
    Doug
    Jul 2004
    Berkeley, CA
    Cheers guys,
    Doug
    I like those vis. Just change frodo buttons from cntrl+? to alt+?. That'll fix the problem I hope
    same problem. I think you were right with your first statement, it changes the focus and thus the shortcuts dont work.
    Looks like I'll either have to see if there's any way to stop it from doing that (I doubt it) or look for another vis.
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    this is the way it should work,
    Im currently using twistedpixel
  1. keyboard shortcuts dont seem to work
    By liquid_smoke in forum FrodoPlayer
    Last Post: 01-31-2005, 02:31 AM
  2. iguidance keyboard shortcuts?
    By liquid_smoke in forum GPS
    Last Post: 12-03-2004, 10:56 AM
  3. Laptop keyboard not working
    By Embassy in forum General Hardware Discussion
    Last Post: 10-11-2004, 01:23 PM
  4. USB keyboard stops working! (zippy)
    By XxAndyxX in forum General Hardware Discussion
    Last Post: 05-23-2004, 04:58 PM
  5. Working without keyboard - how?
    By Matthew_sl in forum General Hardware Discussion
    Last Post: 01-15-2000, 05:42 AM
