Hi,
the options "TIME REMAINING" and "Elapsed Time" on main screen are switcht.
if you use "Elapsed Time" and you restart frodo then it became "TIME REMAINING"
"TIME REMAINING" switches to "Elapsed Time" on main screen.
My settings are set to showtTrack Time Remaining. If I exit FP, then restart it, it resumes the same song as it should, but starts up showing the elapsed time of the track. If I look in the settings, it's still set for Time Remaining. Upon exiting the settings, it reverts back to Time Remaining.
Even checking the ini file for the TIME=REMAINING shows it's set correctly, as another post mentioned.
99 Ford Ranger - Bagged and laying frame
Current Carputer project:
Done:
Custom mounted 7" LCD w/ TSK in radio bezel
Custom center console for relocated headunit
Via Epia M10000
GPS
MP3
OPUS PSU
DVD
Hi,
um ok, justme1 what the hell are you doing?
@Pepe
"Even checking the ini file for the TIME=REMAINING shows it's set correctly, as another post mentioned"
wouldnt this mean there is already a bug report about this? I dont have time to check now but i believe ive read a few post about this issue already.
dupe
public appoligy to justme1:
sorry for biteing your head off and also the misunderstanding in your post above.
apartently what he's saying is if you change the option to elapsed time it will be time remaining and vise versa. Sorta like the option is reversed, but works.
Not sure if this works or not but give it a try.
