Results 11 to 20 of 22
Thread: SOUND_goes to 100% when going from "media" to "dvd"
  1. #11
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    You should be able to load the individual .VOB files into it or into WMP. I may be totally wrong, but it's worth a shot to see what codecs get loaded into the graph. You can then right-click on each one and hit Properties. Some have adjustments. Like the AC3 one can be bypassed for wave/mp3 and they won't mess with the volume. Some other codecs are just poorly written and need to be removed/replaced.
  2. #12
    Maximum Bitrate Maņana's Avatar
    Jul 2004
    Sweden
    This doesn't seem wrong to me?
  3. #13
    Mar 2004
    Florence Yall, BFKY
    Oh that's odd. Mine goes through an MPEG splitter first, then to the MPEG decoder and AC3 decoder. I guess yours goes directly to the sound card from the DVD player or something?
  4. #14
    Jul 2004
    Sweden
    Well, actually I don't know. I thought intervideos windvd codec did everything? I'm just useing the built in soundcard in my m10000.
  5. #15
    Mar 2004
    Florence Yall, BFKY
    I guess the audio is somewhere else. This is what usually see. The audio gets split and sent to this stupid AC3 filter:
  6. #16
    Jul 2004
    Sweden
    aha, okay. But frodo said he uses the windvd codec just as i do, and that it works well. So it must be this "elcard mpeg2 demultiplxer", otherwise i have no clue :s What is the demultiplexer anyway?
  7. #17
    Mar 2004
    Florence Yall, BFKY
    The demultiplexer splits the audio and video chunks from the MPEG2 stream. That Elecard one works good for me, but it may be a newer version or something. The ACE mega codecs pack is always a good thing to have. You can install and uninstall different ones to find out which works best.
  8. #18
    Jul 2004
    Sweden
    I allready have the ACE mega codec pack. I'll try to get in touch with frodo (since he does't seem to read this thread ) and ask his what version he recommends...
  9. #19
    Jul 2004
    Sweden
    Well, i havent talked to frodo, since it feels kinda stupid to send a pm. I'm quite sure hi has read all posts in this thread since its about his own software :P
    Tough, i have found a workaround.
    The problem i have is that i keep my front and rear channel volyme att a constant value (50%) and then i adjust the volume with the wave control. When i start windvd it puts the front channel sound to 100%, and that is quite disturbing. I found out that windvd doesnt really put the volume at 100%. It just resumes the last used volume. (yes, it took me a few months to realise that )
    So, just start Windvd and adjust it to the wanted volume and shut it down. That means it will adjust the volume to the allready set ?amount? at FrodoDVD start.
    (****, i feel kinda retarded at the moment. It really took me that long time to come up with that thougt? )
  10. #20
    Mar 2004
    Florence Yall, BFKY
    Heh. Well, it's better to just adjust the master volume anyway. Wave is a percentage of master and media player/winamp is a percentage of wave, so I set everything (wave, CD, line-in, players, etc.) at a level that sounds about the same and control master to adjust the volume of everything at once. Although nothing should really mess with the wave volume automatically. That's just bad programming. That reminds me of that MIDI plugin for Netscape that would do that with the MIDI volume. Ack!
  1. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 11:54 AM
  2. no DVD picture w/ media player and nvdvd
    By warnockm in forum General Hardware Discussion
    Last Post: 01-04-2005, 08:29 PM
  3. Beyond Media out tomorrow!!!
    By Defiler in forum Software & Software Development
    Last Post: 12-04-2004, 01:27 AM
  4. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 12:25 AM
  5. Make DVD fill screen under media engine
    By Mikesz in forum Media Engine
    Last Post: 09-24-2004, 04:57 PM
