Has nothing to do with frodoplayer. It's either a radiator problem, hardware problem,
or a reception problem.
When I switch to FM, and it shows the station I am playing, it is all fuzz until I click on the same button of the station showing. There is also a delay from when you click on a button to when you get the station coming in, like a second or so, but its all fuzz. If you switch out of FM, to something else, and then back in FM, it will not go back to the station, but wait until you click on the button, or there is a delay to when the station decides to kick in. I will try and narrow that down between when it does not go to the station at all, and when there is just a delay to changing a channel or when you open FM. Hope this helps.
Round VIII - [IIIIIIIIII] 30% Have some parts for 300zx Sema car I don't own yet. Will have 10.4" & 7" screen, and more then you can believe. Will add updates to cleancustoms.com, will be sweet. My car is still same, but might change.
[H]4 Life
I'm a lesbian too.
I am for hire!
Its not a reception thing, but I will test Radiator on its own to see if it does the same thing. But the main thing is, is that it doesn't go to the channel it shows on the interface when you open it, until you click on the button. Almost as if the program is waiting for you to decide which channel even though there is one showing. Like it has a default channel it opens to. Do I need to set stations in Radiator?
K
