Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: RESUME after hibernate frodoplayer paused until user input
  1. #21
    Constant Bitrate DJKhan85's Avatar
    May 2004
    Boston, Mass
    I have a similar situation to you guys. After coming out of hibernation, frodplayer loses the sound card aparently. Also if I leave frodoplayer open and then go to hibernation it takes twice as long to resume than if I just closed frodo and hibernated. I can't figure this thing out. The funny thing is that frodo will register the click sounds when pressing buttons. I believe the problem lies with my sound card. I jsut redid my setup and the only differences are that now I have SP2 and am using FDDshow or whatever it is called. Other than that everything is the same.
  2. #22
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    just a quick update with my solution to the "resume from hibernate needing user input before the computer will do anything problem".
    parts: usb optical mouse, cpu fan, tape
    so i taped the optical mouse to the fan and hooked up to my cnx p1900. whenever the laptop turns on, the fan turns on. because the optical mouse sits directly on top of the fan, the mouse starts moving. that solves the input problem.
    the next issue was how to get the mouse to stop moving. having the mouse constantly would screw up a lot of functions in most frontends. to correct this i used girder, autoit, and devcon. onresume, girder executes an autoit script that uses devcon to disable the usb optical mouse. onsuspend, the opposite happens and the mouse is enabled. i've tested it and it does work.
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  3. #23
    Maximum Bitrate MobiTekLink's Avatar
    Jun 2005
    Queens, NYC
    My issues are that I go into hibernate and coming back the touch screen doesnt work correctly until I use a mouse. It's almost like the touch screen is "right clicking' and it gets resetted after using the mouse. Also the touch screen is only highlighting the last operation used before hibernating. :?? Im baffled, I've used all the drivers and disabled "auto right click" on the touchkit utility.
    08 Lincoln Navigator
  1. m10000 doesnt always resume from hibernate
    By fasternfaster in forum General Hardware Discussion
    Last Post: 11-29-2004, 04:21 PM
  2. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
  3. resume from hibernate
    By turbochris in forum General Hardware Discussion
    Last Post: 05-28-2004, 02:11 PM
  4. Trigger script/command on resume from hibernate?
    By tejesh83 in forum Software & Software Development
    Last Post: 10-24-2003, 08:05 PM
  5. M9000 display size on resume from hibernate
    By GingerPrince in forum Software & Software Development
    Last Post: 05-03-2003, 10:30 PM
