Results 1 to 6 of 6
Thread: 2 bugs and now Frodo won't load...
    Jan 2005
    Exclamation 2 bugs and now Frodo won't load...
    Started last week with "Uh, oh - Database error" and program would freeze. Here is what the error log said over and over:
    3/18/2005 - 6:07:59 PM - 91 - Object variable or With block variable not set - frmDB-tmrGetData_Timer - 0 - FrodoPlayer -
    3/18/2005 - 6:08:00 PM - 13 - Type mismatch - frmDB-tmrGetData_Timer - 0 - FrodoPlayer -
    I completely uninstalled and deleted the Frodoplayer directory, then reinstalled. Also reinstalled all 4 of the required programs for Frodo, as per the FAQ.
    Now I get a new error:
    " System error &HB00004001 (-2147467263) NOT implemented"
    with this from the error log:
    3/21/2005 - 6:57:37 PM - 91 - Object variable or With block variable not set - MainModule-MasterListsFillFromQuery - 0 - FrodoPlayer -
    I am using Take 3 of Frodo, and WMP version 10.
    Thanks,
    -Jeff
    Jan 2003
    Ruston, LA
    What have you done to your system ?
    Things don't just stop working for no
    reason, so something caused this.
    Try reinstalling MDAC.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jan 2005
    System changes
    None that I know of, overtly, however I was forced to do a "Boot windows from last known working version" during an F8 start-up.
    After I had done this, I then re-installed MDAC, Visual Basic Runtime SP6, and
    Jet 4.0 SP8
    I then got the database error problem, so I tried to delete then reinstall Frodo.
    That didn't work, so I upgraded from WMP9 to WMP10. That went fine, but I then got the second error.
    I tried the MDAC reinstall again, based on a previous bug post, but the same error was still happeneing.
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    :-( im gettin database error problem too!!
    Mar 2005
    i also got the "Uh, oh - Database error" after I had to "boot to last known working verion". uninstall/reinstall frodo didn't help. i will try to reinstall other components.
    Mar 2005
    looks like reinstall MDAC will fix the problem as stated in this thread
    DATABASE_(FP 1.09t3) Can'nt open databaze
    I will give it a try tomorrow
