Here are the links, explanation below.
FrodoComm
FrodoComm Services Host
What is FrodoComm ?
It's an "Asynchronous Extensible Inter-Process Communication Server"
It's purpose is to allow interprocess communication for apps and services
via a common interface. The docs still need to be written, but some uses
are released as source with the app and the services launcher.
What is FrodoComm Services Launcher ?
It is a small inteface that supports "COM" plugins or services, as well
as plugins written in VBScript or Javascript.
It's primary purpose is to provide a place for hosting services that don't
require an interface, but provide useful things. The services however
do not have to use FrodoComm, so the launcher can be used for other
purposes.
Who would use either of these ?
Well right now, since there is no developer support, no one
But as more developers add support to their apps, the uses
will become obvious. (4 developers commited now, including me)
Any app can join the FrodoComm network, it is not limited to just these
services.
For developers, two interfaces are provided, a user control, and a class
module. FrodoComm.exe itself should not be used directly, the control
or class only should be used, as they are threaded when not run in debug
mode. This prevents blocking.
6 demo plugins with source code are provided for developers to get
their feet wet.
4 in VB6
1 in VB Script
1 in Javascript
More language examples will follow, including C#, VB.NET, C++, and Delphi.
I hope to be on hand to give out advice and more documentation
as necessary for use.
A list of dependencies for the apps is as follows:
(Links to come, most developers will know how to get these)
--MS XML 4 SP2 or higher
--MS Winsock Control
--SAPI 5.1
--IE 6
--MS Script Control
--MS Scripting Runtime
For devs wanting to check it out and start working now, check the app
folders for some instructions and source code. Also a demo app is provided.
Note: To bring ServicesHost visible after launching, either relaunch, or
press CTRL + SHIFT + ENTER.
I know I haven't explained enough, but maybe you devs can ask the right
questions so I can rectify this.
Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
Installed.
-GPSSecure- - GPS Tracking
There are also things such as:
1. pre-defined "canned" messages
2. language extenders for the scripting engines
I will explain these soon as well.
It was a lot to package up !!
[H]4 Life
I'm a lesbian too.
I am for hire!
Yem, I'm one of the developers. Delphi code needed
Things that will be on the network:
iGuidance skin I'm working on
NaviVoice
GammaControl
I will try to answer any questions tomorrow. I must rest now.
I'll be off work tomorrow at 5:00 PM CST.
Later guys.
Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
Also, if I forgot to list any dependencies, or it doesn't work,
please forgive me, as this is the first try at release![]()
[H]4 Life
I'm a lesbian too.
I am for hire!
for the non technical idiots (me) what does this mean in laymens term? i read all that but it went over my head.![]()
Its for developers. So expect to see more integrated development between developersOriginally Posted by theheel
So it will be easier for me to talk to FP, and to the program that I am making. Also FP will be able to talk to my program directly, as well as with NaviVoice. Its a web basically
Also programs will now be able to ask others about what they are doing, etc...
yea im with you!Originally Posted by theheel
please explain that one, i didnt know IG can be skinned yet.....Originally Posted by 0l33l
Well, probably it can with help from this... Guess "skinned" means a sepparate skinnable program that controls and shows iG?Originally Posted by camsgs3
