Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 73
Thread: FriBruMet
  1. #51
    Mar 2005
    Pomona, CA
    I like it!
    I would love to see a new GPS and XM skin for when frodo releases the patches. I am still running your skin and have to say that it is the cleanest one out there by far. It would be PERFECT if the GPS window wasnt so ugly (not your fauly) and if the XM skin matched and was able to minimize/switch so that it didn't take so long to open and you could switch to GPS from XM. From what it looks like, frodo is going to resolve almost all of those issues with a few patches (I really hope!).
  2. #52
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Just tried this (daytime) in the car, works great, better than my skin I am working on.
    It also looks great, nice, clean, simple. all that a skin should be.
    Its given me a few ideas on dark skins that suffer glare, I want a dark daytime skin to match my dark interior, but my current dark skin disapeers in glare.
    I'm working on it and after seeing this I think I have cracked it. (I also have to use big buttons as my touch screen is damaged and wont calibrate as it should)
  3. #53
    Variable Bitrate Frigor's Avatar
    Aug 2004
    Faenza, Italy
    Quote Originally Posted by lez
    Thank you...
    me too have dark interior in my car and i'd like a dark daytime skin, but me too have problem with glare... so i decided to make a skin that won't disapeers... good luck with your skin...
    but... what about this project?
    Full digital dash app
    BMW E36 Project [ =======§== ]
    Hardware:
    Lilliput 7" Touchscreen - Epia M-10000 - HQCT 1.0 FM Radio - 2.5" 80Gb - USB GPS
    Software:
    FrodoPlayer 1.10 & MapMonkey with FriBruMet Skins by Frigor.
  4. #54
    May 2005
    Need help
    hi i wanted to know if someone has made a skin for Honda ??? how do i change the phone link. i have installed the phone software but the button doesnt work.
    someone please help thanks alot for amazing effort.
  5. #55
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    I thought I gave you the Honda Skin *Day* (maybe what you are after is the night skin)
    You have to open FP .ini and put the path of phoneControl in it.
    Thanatos.
    EDIT:
    If I'm no mistaken here is PhoneControl=APP1.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  6. #56
    May 2005
    Quote Originally Posted by thanatos106
    Thanatos.
    EDIT:
    Hi thanks for the reply... i am very new at this and would really appreciate it if you can explain how would i go about doing this...in some detail...
    thanks again
  7. #57
    Nov 2004
    Open Frodoplayer folder look for Frodplayer.ini go down until you see something like this:
    APP1MINI=FASE
    APP1COMMANDLINE=(put path of PhoneControl here)
    APP1COMMANDLINEOPTIONS=NONE
    APP1PAUSE=FALSE
    Thanatos.
    Nissan Aux-in MOD
  8. #58
    May 2005
    Thumbs up
    APP1MINI=FASE
    APP1PAUSE=FALSE
    Thanatos.
    thanks alot ...
  9. #59
    May 2005
    I strated using this skin a couple of days ago - quick question regarding the volume controls. When I press and hold vol up or vol down - the volume goes up or down for a few seconds then stops even if I'm still holding it down. Then I have to click somewhere else on the screen and then I can go back and click vol up or down again. Is this normal or am I missing something? Any help appreciated!
  10. #60
    Nov 2004
    Quote Originally Posted by vexter0944
    This happened to me and I discovered that there are to possible problems:
    1.If you using the TS and this is happening is cus a settings in the configure utility. (if I recall right is a setting in the advance mode *my screen is in my car so no way to tell you the exact steps right now*) Play a little bit with it.
    2.Check setings 1/misc1 and 2 in FP and look for volume mode % and volume button speed.
    Thanatos.
    Nissan Aux-in MOD
  1. Frigors Skin is RELEASED!
    By nappyjim in forum FrodoPlayer
    Last Post: 03-22-2006, 06:40 PM
