Are you planning on releasing the PSD's so that the apps screen can be finished?
I'm guessing that you've based your radio skin on Feb's brushed Aluminium one. It has the same error from his early versions.
C!
Am I the only one getting this error when I download the XM skin?
! C:\Documents and Settings\XXXXXXXXX\My Documents\XMBrightlife.rar: Unexpected end of archive
And these when I try to extract it:
! C:\Documents and Settings\Steve.fay\My Documents\My Music\XMBrightlife.rar: CRC failed in XMBrightlife\EQ\backdown.jpg. The file is corrupt
! C:\Documents and Settings\Steve.fay\My Documents\My Music\XMBrightlife.rar: Unexpected end of archive
ATVMS.com
C!
http://carpc.riposte.net
I reserve all rights in connection to each post I author, without exception.
Awesome, used it on the psone 5" screen this morn and it looked fine, big thanx!
2000 Sunfire build 100%, or is it ever really 100%?
FYI the "back" button on the equilizer on the XM radio part does not have the correct width.
To re-create. Launch XM (frodos alpha) and press the EQ button. EQ skin loads up. Now hit back button. Width of back button is wider than the .ini file allows for so you have to press the very left portion of the button along the edge of the screen to make it actually go back.
So nobody else is getting the error when they try to open the xm rar file?
ATVMS.com
I thought someone was developing this for use on RR.... copyright?
This has been in the works for FP for a while if I am correct in my thinking.
The skin doesn't work. I changed the frodoplayer.ini file and the screen just stays white.![]()
From what I remembered it was announced for ME first, by p2k, and everyone jumped on it... since then it has been ported to FP, and I thought it was being ported to RR (there is a post there!)
Originally Posted by Erwin
The skin does work. Try setting it up again. I've had it on since 2am last night. (yeah, u guys dragged me outside at 2am to put this in) Make sure you follow the instrucitons at the beginning of this post.
