I am having two problems.
1 - Carweb -
How do you install carweb into two different directories like you show in your ini file. If I install it in one, it doesn't run in the other. If I copy carweb.exe to the other, it still doesn't run.
2- frodopictures
I don't know of any ini settings for this application.
When I click on it it says file not found or not configured.
If I change the ini information for pics to be what the plst is, then, frodopictures runs fine. It also runs fine in the tv spot. Are the settings for pics in the ini file correct? What should I do?
DVD and carweb run correctly.
Still looking for a 350Z or Fairlady Z logo. Will be glad to make my own after you release the psd.
Take your time. Family comes first!
LinkBack URL
About LinkBacks
