Yes, i understand the plugin concept-all the rest you have posted work fine.
I had the .exe and .dll's in the C:\Program Files\CDRIP\DAY and the jpegs in a sub dir C:\Program Files\CDRIP\DAY\SKIN
I changed it and moved the program files to C:\Program Files\CDRIP\DAY\SKIN
and got the same result?
What is the cdrip.ini file supposed to look like, mine is:
# Skin Path (If running from within RR this is obtained automatically)
# If left blank, the subfolder "Skin\" under the application folder is used.
#skinpath=<PATH>
I haven't changed it-this is the default setting.
LinkBack URL
About LinkBacks
