what window are you talking about??Originally Posted by Tim Lake
All the APP or just CarWeb??
Thanatos.
How do you move the window, it always loads halfway down my screen and to the left, fine in 1024x768 on my test motior, not so hot on my 800x600!
I also cannot get the programs (carweb etc) to work. I still get the message "File Not Found or Not Configured" and I have double and triple checked FP.ini
Can you help me or am I stupid?
Thanatos.
No the whole app.
*EDIT* OK, I've sorted the position issue, I just turned off the advanced positioning option and made the program full screen (ideal).
The main problem I'm having is getting the apps to work and it is on all of them (Pics, TV, Net etc). It is like the fp.ini has the wrong paths but they are definately right
OK......
Have you seen that .ini file that is inside FrodoPlayer folder in my skin?? (same instructions that I posted in the first page)
APP1MINI=FALSE
APP1COMMANDLINE=C:\Program Files\TV plugin\Tvplugin.exe
APP1COMMANDLINEOPTIONS=NONE
APP1PAUSE=TRUE
APP2MINI=FALSE
APP2COMMANDLINE=C:\Program Files\MI main\Night\ME.exe
APP2COMMANDLINEOPTIONS=NONE
APP2PAUSE=TRUE
APP3MINI=FALSE
APP3COMMANDLINE=C:\Program Files\MI main\Day\ME.exe
APP3COMMANDLINEOPTIONS=NONE
APP3PAUSE=TRUE
APP4MINI=FALSE
APP4COMMANDLINE=C:\Program Files\CDRip Main\Night\CDRip.exe
APP4COMMANDLINEOPTIONS=NONE
APP4PAUSE=FALSE
APP5MINI=FALSE
APP5COMMANDLINE=C:\Program Files\CDRip Main\Day\CDRip.exe
APP5COMMANDLINEOPTIONS=NONE
APP5PAUSE=FALSE
APP6MINI=FALSE
APP6COMMANDLINE=C:\Program Files\Carweb main\night\CarWeb.exe
APP6COMMANDLINEOPTIONS=NONE
APP6PAUSE=FALSE
APP7MINI=FALSE
APP7COMMANDLINE=C:\Program Files\Carweb main\day\CarWeb.exe
APP7COMMANDLINEOPTIONS=NONE
APP7PAUSE=FALSE
APP8MINI=FALSE
APP8COMMANDLINE=C:\Program Files\PIC plugin\PICplugin.exe
APP8COMMANDLINEOPTIONS=NONE
APP8PAUSE=FALSE
Those are the default folders for every skin (day/night) this doesn't mean that you can't make you own folders but if you do you have to change the path of that APP in FP .ini
In my skin I took of all the native buttons and replaced them with APP so for example:
APP2 belongs to Snes emulator night and APP3 to day, so I just put the path where I installed the APP (having in mind that for each APP you have to make to folders *night/day* plus for this special APP you have to install it in the default folder too.
So for every APP two folders (use installer and then make a copy)
Thanatos.
I've done that, and my FP.ini is updated to reflect the slightly different installation directories I used. They still refuse to load
The ini goes into the root of FrodoPlayer yes?
Post you .ini file.
Thanatos.
APP1MINI=FALSE
APP1PAUSE=TRUE
APP2MINI=FALSE
APP2COMMANDLINE=C:\Program Files\Mobile Emulator\Night\ME.exe
APP2PAUSE=TRUE
APP3MINI=FALSE
APP3COMMANDLINE=C:\Program Files\Mobile Emulator\Day\ME.exe
APP3PAUSE=TRUE
APP4MINI=FALSE
APP4COMMANDLINE=C:\Program Files\CDRip\Night\CDRip.exe
APP4PAUSE=FALSE
APP5MINI=FALSE
APP5COMMANDLINE=C:\Program Files\CDRip\Day\CDRip.exe
APP5PAUSE=FALSE
APP6MINI=FALSE
APP6COMMANDLINE=C:\Program Files\Carweb\Night\CarWeb.exe
APP6PAUSE=FALSE
APP7MINI=FALSE
APP7COMMANDLINE=C:\Program Files\Carweb\Day\CarWeb.exe
APP7PAUSE=FALSE
APP8MINI=FALSE
APP8PAUSE=FALSE
I meant like .rar you .ini file and post it as a attachment.
Thanatos.
Anyway I checked that info and it looks good I really don't know what to tell you besides check the APP if they open by themselfs.
Thanatos.
They all launch ok themselves. If it helps, I dn't think it can even 'see' the ini file cos no matter what I put in it, it won't launch anything. Do I have to do anything special with the skin files? I just put the folders RexBruMet day and RexBruMet night in the skin directory and selected the skins from inside frodoplayer settings.
