Results 1 to 10 of 11
Thread: .Ini question
    Apr 2006
    .Ini question
    I did my searching (maybe not well enough) and I'm a bit confused about editing the .ini files. I understand how the location of items of placed by percentages left and top.
    Are width and height in pixels? since the sizes in the ini file dont seem to match what photoshop seem to say they are.
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    yes, if I remember correctly, the width and height is in pixels.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Apr 2006
    Thats what I read but for some reason the .ini files I compare to with the image size in photoshop are so far apart.
    1 button I was testing was 50x50 pixels acording to photoshop but in the .ini file it says 9x15 thats why I asked
    Dec 2003
    New York
    post a image and I'll check.
    Installed
    Apr 2006
    here is the button and and the part of the ini file
    PLAY_LEFT=56.05
    PLAY_TOP=86
    PLAY_WIDTH=9
    PLAY_HEIGHT=15
    Dec 2003
    New York
    is this from an existing skin?
    if they set the width to 9 pixel, that doesn't mean the button is 9 pixels wide, it only mean that the clickable are will be that wide.
    Installed
    Apr 2006
    Yes it is forgot what one it was exactly and Im a t work right now so I cant check. Im just tring to figure this stuff out so I can create my own skin.
    Quote Originally Posted by Quattro
    Thats what I thought also but it seem that no matter where i click on the button it registers in the full skin.
    OK made it home and messed with the ini changed it to the pixels photoshop said thay were and it blew everything outta wack. SO Im guessing its not pixels
    Dec 2003
    New York
    No, it is in pixels, trust me.
    http://mywebpage.netscape.com/mighty...ning%20101.pdf
    which skin are u looking at??
    Installed
    Apr 2006
    Just started looking at the brightlife this time. IF i change the pixel size in the ini file for the vis/album art window from this
    VIS_OR_INFO_LEFT=2.9
    VIS_OR_INFO_TOP=74.6
    VIS_OR_INFO_WIDTH=21.1
    VIS_OR_INFO_HEIGHT=25.4
    VIS_OR_INFO_FORECOLOR=16777215
    VIS_OR_INFO_BACKCOLOR=0
    VIS_OR_INFO_FONT_NAME=Tahoma
    VIS_OR_INFO_FONT_BOLD=False
    VIS_OR_INFO_FONT_ITALIC=False
    VIS_OR_INFO_FONT_SIZE=12.5
    VIS_OR_INFO_FONT_STRIKETHROUGH=False
    VIS_OR_INFO_FONT_UNDERLINE=False
    to
    VIS_OR_INFO_WIDTH=125
    VIS_OR_INFO_HEIGHT=165
    which photoshop says it is. it blows it way outta wack
    Variable Bitrate Frigor's Avatar
    Aug 2004
    Faenza, Italy
    No.... width and height are in percentual of the portion u are editing.
    If u are editing menu and menu is 100x100% big then the with and height are in percentual of the 100x100% of your skin.
    If u are editing menu and menu is for exemple 100x80% u have to keep in mind that the button width and height are in percentual of the portion u are editing, not the whole skin.
    BMW E36 Project [ =======§== ]
    Hardware:
    Lilliput 7" Touchscreen - Epia M-10000 - HQCT 1.0 FM Radio - 2.5" 80Gb - USB GPS
    Software:
    FrodoPlayer 1.10 & MapMonkey with FriBruMet Skins by Frigor.
  1. Replies: 2
    Last Post: 05-02-2006, 06:15 PM
  2. Forum Etiquette
    By Enforcer in forum Newbie
    Last Post: 01-09-2006, 06:58 PM
  3. Paint And Polish Question
    By gboy in forum Fabrication
    Last Post: 08-13-2005, 08:22 PM
  4. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 10:03 AM
  5. Replies: 5
    Last Post: 02-02-2004, 10:52 PM
