Results 1 to 5 of 5
Thread: Cant get 800x600 working?
    Variable Bitrate we87's Avatar
    Nov 2005
    Dallas, TX
    I downloaded a few different 800x600 skins, and it still displays as 800x480?
    What exactly am I doing wrong here?
    TIA
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Everything is in the car and working.
    I painted the cilpboard mount and it looks good.
    Shutdown/Startup is working excellent!
    View My Progress Here
    Elsewhere
    You don't search, do you?
    Well I went against my better judgement
    How about the Wiki?
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Is either what DP told you or untick "advance display options" in settings 1.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    May 2005
    Vienna, VA
    To be fair to the noob, that thread was like 2 years ago*.
    *which was probably the last time FP got updated anyway.
    Nov 2005
    Dallas, TX
    Thanks for the information...But just for the record, I did search on both google and this forum, and I even read the FAQ section... But in Frodoplayer I could not find the advance display options anywhere in the settings (both set one and set two, and all the other ones)....
    I also read about changing the frodoplayer.ini file to not accept the advance display options, but in the .ini file the option wasnt there:
    The advanced settings are defined in "frodoplayer.ini"
    Under the [MAIN] tag
    USE_ADVANCED_SCREEN_SETTINGS=True
    Under the [ADVANCED] tag
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
  1. Working Destinator PN SDK !
    By celo in forum Map Monkey
    Last Post: 02-08-2010, 06:18 PM
  2. Replies: 1
    Last Post: 11-13-2004, 10:35 AM
  3. Probl. embedding FrodoDVD with 800x600
    By swissRv in forum MediaCar
    Last Post: 09-14-2004, 05:39 AM
  4. "Stretched" 800x600 MediaCar F-CNS skin available
    By febsperanza in forum MediaCar
    Last Post: 06-08-2004, 01:56 AM
  5. Replies: 0
    Last Post: 12-10-2003, 05:37 AM
