Quote Originally Posted by tom2112
I tried it here at work, and it works. Things are stretched, and the aspect ratio is a bit screwy. But it works just fine. I really should try the new skinning tools and see if I can do any better (this time) with my own skin.
Frigor: would you mind if I used your skin to base mine from? I'm thinking all I would do is stretch things and maybe move a couple things around for a portrait layout.
If u are able to download the psd files u can edit anything u want to made your own skin... the suggest i give u is to take a skin (IMGs) rotate it and re-edit the ini files with some tool or simply using a text editor...
Good luck!
