It's been a loooong time since I played with FP. How about going with RoadRunner? It's designed to work with iGuidance.
I am using iGuidance with Frodoplayer and I need to know how do I resize the window. The reason I want to resize the window is because Frodoplayer puts a bar on the bottom with track options like next and previous, but that bar covers the iGuidance bar that has speed and other information. I've uploaded a picture to help show what I'm talking about.
[media]http://i36.tinypic.com/nplue1.jpg[/media]
I've looked through the .ini files and I cant find anything that was helpful. If anybody can help, I would truly appreciate it. Thanks in advance!
Carputer Progress
[||||||||||] 100%
Finally Installed!!
Everything is in the car and working.
I painted the cilpboard mount and it looks good.
Shutdown/Startup is working excellent!
View My Progress Here
Want to:
Thanks for the reply.
Ill be honest, I dont really keep up with the community like I should. But when I first started out I tried all of the front ends possible and in the begining Mobile Impact is the one that stuck with me. But after I kept playing around Frodoplayer really just fit me the best. I have tried RoadRunner and personally I never liked the way it functioned. Maybe I just never set it up correctly, but I just didnt like it. Thats why I stick with either Frodoplayer or I use Winamp with a big button skin.
Carputer Progress
[||||||||||] 100%
Finally Installed!!
So nobody knows how to resize the GPS window in order to still see the bar?
Carputer Progress
[||||||||||] 100%
Finally Installed!!
2004 Impreza WRX CarPC Install
I am willing to host any legal downloads that may benefit the CarPC community - PM for info
"When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
DG4L
Well from what I figured out, if you open iGuidanceUMPC.exe by itself, and make sure its not full screen when you open then close it, that makes it embed better in Frodoplayer.
However, I upgraded to IG4 and everything fixed itself![]()
Carputer Progress
[||||||||||] 100%
Finally Installed!!
