Results 1 to 5 of 5
Thread: FrodoPlayer SkinMaker Alpha Release
    Jan 2003
    Ruston, LA
    Ok, I've been wrestling whether to release this yet, but I'm sure some
    of you would like to try your hand at making a skin, so here is an alpha.
    It should be stable.
    Instructions:
    Under the skins folder, there will be a directory for each skin.
    Under each skin folder will be a folder for which section of the app
    skinned, currently the only one in here is "BBD", or "Browse by Directory"
    All the graphics need to be present in the directories to work properly, my
    suggestion is to just copy one of the working skin directories, and replace
    the graphics. The graphic types supported are GIF,JPG,BMP, if you replace a
    graphic with a different type, you must load that graphic in the skinmaker
    and save the ini file so the skin will know which graphic to load, ie
    say you have a play.gif and a play.jpg, the skinmaker needs to know which
    one to load.
    The skinmaker will let you work in fullscreen or windowed mode. And at any
    resolution. This will allow you to custom taylor widescreen or strange modes.
    All skins will scale to any resolution, however, resolutions will look best when
    displayed in the same aspect ratio as originally created.
    Sometimes the listboxes may need to be adjusted if loading a skin at different
    resolutions, but this is a limitation of the listbox I use, not the skinmaker.
    However this should not be too much of a problem as I don't see people
    changing resolutions often after they are set up, so just adjust once at
    the desired display resolution and save the skin.ini again.
    List icons cannot be changed inside the skinmaker, but can be replaced in
    their respective folders. The next time you load the skin, the icons you
    replaced in the folders should show up. Icons for the directory list and
    playlist must currently be in BMP format only, sorry, will fix later.
    Please if you make a skin, post a screenshot in this thread.
    Also, remember, this is alpha, so bugs may exist, please post them with
    an appropriate amount of courtesy and profesionalism.
    And without further wait, here is the skinmaker.
    Link Removed Was for earlier unreleased FrodoPlayer.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Maximum Bitrate osirisdon's Avatar
    Feb 2003
    South Florida
    Thanks will give it a shot tonight.
    Jan 2003
    Ruston, LA
    anyone tried it yet ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Maximum Bitrate Seraph's Avatar
    Jun 2003
    Elmhurst, Illinois
    not yet. I will download it in a few minutes. I had to reinstall XP. Longhorn was just *****ing me off. MS got a really bad review on that one from me. So I am in the middle of re-install.
    Good news is that I found the LCD driver card which was missing so my 6.5" LCD is working now. Bad news is that I killed the video out (not VGA out) part of my espressoPC and I have to ship it back and it will take about 2 weeks to repair.
    - Lwin M. Maung
    If it's stuck, force it. If it breaks it needed replacing anyway
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Meridian, Mississippi
    I am admist the playin. MUHAHAHAHAHAHAHA
    Quote Originally Posted by menudude View Post
    thank you all for your help minus the useless post by sjlucky...
