Originally Posted by ddogg_777
well unless it crashes
Well, since Frodo said that it remembers where it was last set I suppose if you have it at 100% then that's where it will always be....problem solved right?
[H]4 Life
I'm a lesbian too.
I am for hire!
haha....Originally Posted by frodobaggins
Actually mine seems to like 14%...when I first enter, it will revert to where it was...then, sometimes it will crash (sometimes I am a little trigger happy, might be overworking it as it is loading) and when I restart it, it stops the volume at 14%. Also, if I go into the menu to adjust settings, it likes to revert to 14% also.
Still working with it, and finding stuff, and learning...so far so good. The program is easy to understand and use..Very user friendly. It will be interesting to see where you go from here...if we get a program this good as a beta, the future looks pretty bright
BTW...how do you tell which level you are at? I "think" I am up to date with 1.0.3 but how do I know if the patch worked? It still shows 1.0 on the main screen.
2005 Ford Focus ST
The next version will include the revision on the about tab.Originally Posted by gospeed.racer
In the meantime you can get a propeties on the filename.
[H]4 Life
I'm a lesbian too.
I am for hire!
I'd just be happy if I could minimize it to the task bar or maybe the system tray.Originally Posted by Naamanf
You actually never have to go to mini mode if you don't want.Originally Posted by TimmyM
All you need to to is put frodoplayer back IN advanced screen settings
and then set the position and size to show your task bar.
Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
while playing movie files i can go full screen by clicking small movie, but once full screen i have to hit esc on keyboard to get minimized again...couldnt you set it up so you just have to click on video to minimize..also a few other things to make it more touchscreen freindly......thanks alot for your hard work.
great peice of software....
Try double clicking the movie while in full screen. It should go back to to small window. This works on my TS.Originally Posted by xtreamvette
It's skinnable....Originally Posted by Naamanf
[H]4 Life
I'm a lesbian too.
I am for hire!
1) In mini-mode, and I know this will sound silly but I would like the text to scroll the other way.
2) In full mode, I wold like to see text scroll for the "visual" area
3) Since the area of the text in the play list is fairly limited, I think it would be better to have <song name> - <artist> display. Now if the name of the artist is long (and I have a few) I can't see the name of the songs.
4) An option to not allow full screen visualization. Windows media player vis. in full screen mode can cause a problem for me in two ways. If I use a simple one (like the bars) I need to hit ESC and can't. If I use a complex I end up with a black screen after the video mode switch (I tried changing the res.)
