Page 17 of 17 FirstFirst ... 7891011121314151617
Results 161 to 169 of 169
Thread: Bug Reports
  1. #161
    Jan 2003
    Ruston, LA
    Quote Originally Posted by benjuzzo
    I just installed windows xp service pack 2 and frodo player not running anymore.... why?
    It said anything for database not exist or database not ready....
    Works fine on my laptop with sp2.
    Do you have all the requirements ?
    Also try to uninstall and reinstall FP.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  2. #162
    Low Bitrate fireball106's Avatar
    Jul 2004
    Israel
    I'm running it on 2 computers using SP2 and it works fine!
    If you don't want to lose your settings, you could try installing Frodo on another directory, then copying MediaLib.mdb from the new to the old installation directory, then Synchronize your files again.
    Lior "Fireball"
  3. #163
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    I just reinstalled my CarPC with Windows XP SP2 slipstreamed 2 days ago.
    I only installed WMP10 and FrodoPlayer 1.06 and 1.08 patch and all windows updates and so far everything is working fine.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  4. #164
    Jul 2004
    Israel
    Lightbulb
    When you drag/click the track-position-bar, then while the mouse button is down you go a little bit outside of the boundaries of the bar, then you release the mouse button - it "aborts" the action and does not move the song position at all.
    This is kind of annoying as many people use touch screens which are not a very accurate device.
    BTW: this does not happen in stop mode, only in play mode.
    In Winamp, for example, this is done correctly, and even when going outside of the boundaries, it still moves the song position to the nearest point.
    Lior "Fireball"
  5. #165
    Jan 2003
    Ruston, LA
    Quote Originally Posted by fireball106
    I've noticed it. I just haven't figured out how to fix it yet.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  6. #166
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    installed frodoplayer on my laptop to test before loading it onto my car pc but i'm having a hard time. does anyone know if frodoplayer should work with xp pro sp2 windows media player 10? the first time i load up frodoplayer it works fine. the next time it freezes and i have to kill it with task manager. there is nothing written to the error logs. i'm thinking it will work fine in my carpc since it's still running sp1 and wm9. i guess i'm just killing time waiting for 1.09.
    <edit
    nevermind. i figured it out. i had fddshow installed and it was causing frodoplayer to hang. uninstalled fddshow and everything works great.
    edit/>
  7. #167
    Oct 2004
    s.cali
    Whenever i stop 1.08 and there is a song running, when i restart it, it freezes, however if i change my ini to not have a song playing, it works fine. there are no errors or anything. All that happens is the background loads, then it just freezes. I am on xp pro sp2 and using wmp10 if that helps at all.
  8. #168
    Jun 2002
    Malaysia
    Frodo.. can we turn jump mode off in FP 1.09?
  9. #169
    Jan 2003
    Ruston, LA
    Quote Originally Posted by masch
    Sure, I gotta compile a few more times anyway.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. Bug Reports
    By frodobaggins in forum PV Bugs
    Last Post: 02-17-2005, 01:01 AM
  2. Official Bug reports.
    By skippy76 in forum V.O.I.C.E.S
    Last Post: 11-08-2004, 12:37 PM
  3. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 05:32 PM
  4. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
