Page 2 of 17 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 169
Thread: Bug Reports
  1. #11
    Jan 2003
    Ruston, LA
    Quote Originally Posted by freestyler
    mine was blank, nothing in the file....
    it just started to add files to the database and then it freezes
    1.0.3
    how far did it get ?
    do you know the last file it found ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  2. #12
    Maximum Bitrate Naamanf's Avatar
    Sep 2003
    Colorado
    I am still having the program crash when coming out of standby. I no longer get the Radiator pop-up box. I also notice that after a re-boot the program will crash the first time I run it, but work the second time. The error log is also empty. If there is any other info, or anything I can do don't hesitate to ask. I really like this program.
    2007 Tahoe
    Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
    My Install
  3. #13
    Jan 2003
    Ruston, LA
    I'm going to recomplile with SP6 and see what happens.
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  4. #14
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    I have installed 1.03 on both my HomePC and my CarPC.
    On my HomePC it crashes and I get that "has encountered a problem and needs to close." error when it's building the database sometimes.
    On my HomePC and CarPC it gets that "has encountered a problem and needs to close." error when playing songs sometimes.
    I just checked the fperrorlog.txt on my HomePC and it is blank.
    Your using NT 4.0 to code this? SP6 is for Windows NT 4.0 right? Or is it SP6 for VB6?
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  5. #15
    Banned eatyummypuppies's Avatar
    Feb 2004
    li, ny
    There's actually an sp6 for both, but he's talking about the service pack for vb.
  6. #16
    Maximum Bitrate freestyler's Avatar
    Jan 2002
    Chaska, MN
    every single time i build my database now with the latest patched version it crashes with the "has encountered a problem and needs to close." error infamous with WinXP
    it's never at the same point though, sometimes it'll happen around 1800 songs, sometimes 2400, or more.
    this did work with the very first release...
    1997 Jeep Wrangler Rugged Waves
    Ebay Stuff For Sale
  7. #17
    Jan 2002
    Long Island, NY
    I think mines crashing when I just let it sit.
    On my HomePC I just run FrodoPlayer 1.03 and then don't play music. (Press Stop) When I return to it later, it has that error.
    I'll test it again when I leave now to go to my friends party. I'll just let it sit doing nothing and see if it crashes.
  8. #18
    Man
    Man is offline
    Low Bitrate Man's Avatar
    Nov 2003
    Ok it seems to do that XP crash thingy on odd occations, however one thing I found that will almost always make it crash, pull the speaker plug out or put it in.
    Ok it sounds strange, but it isn't when I explain a bit more. The Jack sense or UAJ on my home computers motherboard senses what type of device is connected to the port (speaker, microphone, etc). When this runs it makes popping sounds in my speakers (this is normal) however it keaps repeating it self when your media player is changing volume (at startup) and then FP (FrodoPlayer) crashes. If it runs its test while FP is running it crashes.
    Also on startup sometimes the jacksense just runs for no particular reason, and causes FP to crash.
    Now it doesn't ALWAYS crash when the Jacksense runs just most of the time when it does it crashes.
  9. #19
    Jan 2002
    Long Island, NY
    Yes, I let it sit and it error'd on me.
    Man, are you using a ASUS P4C800-E DELUXE, cause that one also has the jacksence feature.
  10. #20
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Version 1.0.1 ANd 1.0.3 crashes for me right after playing startup.wav with same old "has encountered a problem and needs to close." error on my Win2K/SP4, where 1.0 was launching fine.
    This is whats in my fperror.log file:
    25.4.2004 - 1:35:54 - 68 - Device unavailable - frmDB-LoadSettings -
  1. Bug Reports
    By frodobaggins in forum PV Bugs
    Last Post: 02-17-2005, 01:01 AM
  2. Official Bug reports.
    By skippy76 in forum V.O.I.C.E.S
    Last Post: 11-08-2004, 12:37 PM
  3. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 05:32 PM
  4. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
