Page 4 of 17 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 169
Thread: Bug Reports
  1. #31
    Jan 2003
    Ruston, LA
    Quote Originally Posted by Man
    Sorry for the wait, I've installed everything there (other than Monkeys Audio) and it still isn't working, also everytime I install something new, the first Time I run frodo player, it does that XP 'this program has encounted a problem and must shut down' or something like that.
    Install Monkey's Audio too. If it works after that, I'll know where to dig.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  2. #32
    Man
    Man is offline
    Low Bitrate Man's Avatar
    Nov 2003
    Ok I have installed everything in that announcement, still the same. I found that I DO have that file 'MSCOMCT2.OCX' and I tried registering is with regsvr32 however that did nothing to help, I will reset this computer and see if anything changes.
    Edit:Still doesn't work after reset
  3. #33
    Jan 2003
    Ruston, LA
    Did you install the NEW runtimes ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  4. #34
    Man
    Man is offline
    Nov 2003
    Quote Originally Posted by frodobaggins
    Yep, will install them again, if it makes a difference :S
  5. #35
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    I uninstalled 1.0.1 with the 1.0.3 patch. Deleted the directory.
    I left what my system had installed prior to this 1.0.4 install.
    Downloaded, installed, and ran and tested 1.0.4.
    Got the same usual error while building database while messing with other tabs and options. Re-launched app, synced database and left it alone and it completed.
    I am now going to run it to see if it errors during normal use.
    If I get any errors, I will install all the files in the post "REQUIREMENTS" and re-test again.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  6. #36
    Jan 2002
    Long Island, NY
    I installed the files from the "Requirements forum" and I still get a error.
    I seem to get the error when the player is stopped. When it is playing a MP3 it seems to run fine, but once I press stop and wait a few minutes it errors on me.
    Error log is always blank for me.
  7. #37
    Feb 2004
    trying to help
    i am running win 98se and version 1.0 i thought i added the upgrade to 1.02 or 1.03 but all the player displays is 1.0 so i guess that is what i am running or is there a better way to find out?
    sorry this is so long but i thought maybe even a older versions problems may help with the issues some are having now........well here is a detailed run down of my problems....
    1. when the player goes into hybernate it will not come out it freezes computer. this was not the case for the first few days of running the software but after that now it does it every time...
    2. alot of the time my am or pm for the time displays incorrectly it is half cut off and located under the time instead of after it, this also didnt start till a few days of running.
    3. now when i try to play video that played flawlessly with the player before some of them will not play now but instead will display the dreaded error and needs to be shut down message details are as follows
    FRODOPLAYER caused an invalid page fault in
    module FFDSHOW.AX at 0167:1006d4d4.
    Registers:
    EAX=00000180 CS=0167 EIP=1006d4d4 EFLGS=00010202
    EBX=054b62ac SS=016f ESP=05d0fbdc EBP=00000160
    ECX=054bc8c0 DS=016f ESI=0549dca0 FS=0f27
    EDX=fffffc38 ES=016f EDI=8314c7b8 GS=0000
    Bytes at CS:EIP:
    0f 7f 17 0f 7f 67 08 0f 7f 47 10 0f 7f 6f 18 0f
    Stack dump:
    0d96098a 0f9c107a 0d4c0de0 0e740e2a 40433828 3b3a3639 73643e1a 5b60666e 34372c1c 31302d2f 6758320e 52565c64 000000f0 00000160 00000010 00000020
    4. if i double click on the monkey icon it will also error and need to be shut down details are as follows
    module <unknown> at 0000:00000000.
    Registers:
    EAX=00000000 CS=0167 EIP=00000000 EFLGS=00010246
    EBX=007bfa82 SS=016f ESP=007bf994 EBP=007bfa30
    ECX=00575f55 DS=016f ESI=00008aa6 FS=10d7
    EDX=8171ef04 ES=016f EDI=007bfa38 GS=0000
    Bytes at CS:EIP:
    22 00 00 00 44 9a 58 c1 16 00 60 05 65 04 70 00
    Stack dump:
    00575f55 000006c0 00000018 00000000 00000000 007bfa38 00008aa6 007bfa82 00000000 00000000 00000018 00000000 00000000 00000000 00000000 00000000
    here is the complete error log these 429 acive x errors where there from the start and dont seem to effect anything and the crashing and shutdown errors dont seem to add anything to the error log
    4/27/04 - 8:03:37 AM - 429 - ActiveX component can't create object - frmDB-Form_Load -
    4/27/04 - 8:03:45 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/28/04 - 1:38:16 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/28/04 - 1:38:17 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/28/04 - 1:38:18 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/28/04 - 1:38:21 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/28/04 - 1:38:22 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/28/04 - 1:38:23 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/28/04 - 1:38:38 AM - 429 - ActiveX component can't create object - frmDB-goPlay -
    4/28/04 - 1:46:05 AM - 429 - ActiveX component can't create object - frmDB-imgButton_Click -
    4/28/04 - 1:46:08 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/28/04 - 1:46:09 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/28/04 - 1:46:12 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/28/04 - 1:46:15 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/28/04 - 1:46:17 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/28/04 - 1:46:18 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/28/04 - 1:46:19 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 2:09:34 AM - 429 - ActiveX component can't create object - frmDB-Form_Load -
    4/29/04 - 2:09:43 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 2:09:54 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 2:09:55 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 2:09:56 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 2:09:57 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 2:09:58 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 2:09:59 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 2:10:00 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 2:10:01 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 2:10:02 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 2:10:17 AM - 429 - ActiveX component can't create object - frmDB-goPlay -
    4/29/04 - 2:15:47 AM - 429 - ActiveX component can't create object - frmDB-imgButton_Click -
    4/29/04 - 2:15:52 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 2:15:53 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 2:15:54 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 2:15:55 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 2:15:56 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 2:15:57 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 10:38:33 AM - 429 - ActiveX component can't create object - frmDB-Form_Load -
    4/29/04 - 10:38:42 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 10:38:47 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 10:38:49 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 10:38:50 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 10:38:51 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 10:38:52 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 10:38:57 AM - 429 - ActiveX component can't create object - frmDB-goPlay -
    4/29/04 - 10:39:40 AM - 429 - ActiveX component can't create object - frmDB-Form_Load -
    4/29/04 - 10:39:49 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 10:39:57 AM - 429 - ActiveX component can't create object - frmDB-imgButton_Click -
    4/29/04 - 10:39:57 AM - 429 - ActiveX component can't create object - frmDB-goPlay -
    4/29/04 - 10:40:36 AM - 429 - ActiveX component can't create object - frmDB-Form_Load -
    4/29/04 - 10:40:40 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 10:40:44 AM - 429 - ActiveX component can't create object - frmDB-goPlay -
    4/29/04 - 10:52:02 AM - 429 - ActiveX component can't create object - frmDB-goPlay -
    4/29/04 - 10:52:22 AM - 429 - ActiveX component can't create object - frmDB-imgButton_Click -
    4/29/04 - 10:52:29 AM - 429 - ActiveX component can't create object - frmDB-goPlay -
    4/29/04 - 10:52:37 AM - 429 - ActiveX component can't create object - frmDB-imgButton_Click -
    4/29/04 - 10:52:41 AM - 429 - ActiveX component can't create object - frmDB-goPlay -
    4/29/04 - 10:52:48 AM - 429 - ActiveX component can't create object - frmDB-imgButton_Click -
    4/29/04 - 10:52:51 AM - 429 - ActiveX component can't create object - frmDB-goPlay -
    4/29/04 - 10:52:56 AM - 429 - ActiveX component can't create object - frmDB-imgButton_Click -
    4/29/04 - 10:53:00 AM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 12:10:31 PM - 429 - ActiveX component can't create object - frmDB-Form_Load -
    4/29/04 - 12:10:40 PM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 12:10:44 PM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 12:10:46 PM - 429 - ActiveX component can't create object - frmDB-ModeChange -
    4/29/04 - 12:10:54 PM - 429 - ActiveX component can't create object - frmDB-goMenu -
    4/29/04 - 12:10:57 PM - 429 - ActiveX component can't create object - frmDB-Form_Unload -
    hope this is enough info and helps streamline this great program/player.
    keep up the great work....thanks
  8. #38
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    I got one:
    4/30/2004 - 8:17:52 PM - -2147418113 - Automation error
    Catastrophic failure - frmDB-wmp_Click -
    Cool, a catastrophic failure! Fortunately my PC is still working...
    Anyways, I was just trying to build a playlist and was clicking on the right arrow button when it crashed. I tried again and can't seem to replicate the error though. Weird...
  9. #39
    Jan 2004
    For the MSCOMCT2.OCX file problem... I was able to go to http://www.ascentive.com/support/new...e=MSCOMCT2.OCX and download the file. Don't download the 4meg patch, just the file. Then use the instructions to register it. Worked for me.
  10. #40
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    I do not know if it has been reported, I have problems keeping tracks with all the new posts everyday on the forum about the player.
    Also, I was under the impression that it was a config problem, but I cannot find a way to make it work...
    therefore it might be a bug and I guess I shall report it.
    I have win98 on my setup, and the shutdown button don't go shutdown: it logs off. I have to relog and manually shutdown in order to shutdown. I guess I could make a bat file to call directly the shutdown process, but I guess there should be a way to configure that to work properly.
    anyway, thanks.
    -Mars
  1. Bug Reports
    By frodobaggins in forum PV Bugs
    Last Post: 02-17-2005, 01:01 AM
  2. Official Bug reports.
    By skippy76 in forum V.O.I.C.E.S
    Last Post: 11-08-2004, 12:37 PM
  3. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 05:32 PM
  4. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
