Page 6 of 17 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 169
Thread: Bug Reports
  1. #51
    Jan 2003
    Ruston, LA
    Quote Originally Posted by IIJasonII
    ok i attached one of the playlists here, it looks like for all the playlists it does shows some of the songs with just the artist-title but for the rest it has the full path...
    Your playlist has several problems. The playlist has the song info above for some and not for others, it either needs to have the info for all, or for none. I parse them two ways, playlists with info, and playlists without. If you notice, not all of your songs showed up after your info stopped, it skipped every other one and each song actually had the title of the one above it.
    Also, I do not support relative paths. Because there is no way to know what
    they are relative to.
    The best thing for you to do would be to make .fpp playlists, as they are the best supported.
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  2. #52
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    I've installed 1.0.6 and 1.0.7 and now I can't build playlist. I make a playlist, go to "save" enter title, then when I try to play there's nothing in the playlist. Also after i press save I can see black text along the left side it the area that's gray. I hope that makes sense. If not I can post a pic of it tomorrow.
  3. #53
    Jan 2003
    Ruston, LA
    Quote Originally Posted by TimmyM
    I'll take a look at that in the morning. No one will believe this, but I am going to bed
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  4. #54
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    If you change the name or remove the directory for the last selected skin, it will just show a grey window, and you have to close it from Task Manager.
    Just a quick check to see if the directory exists should fix that, and get it to load directly to Settings to change the skin
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
  5. #55
    Jan 2003
    Ruston, LA
    I have fixed it, I will post up a fix in a few hours.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  6. #56
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    When browsing the music by directory view. If I exit, and then re-run FrodoPlayer 1.0.8 the song that was on last starts playing, but the playlist window is empty which causes it to stop after the song finishes.
    Can you have it save or refresh the playlist view when it resumes if in directory view mode.
    Also, the volume resume still increses when i try to turn down the volume via Griffen PowerMate and/or IR remote.
    Thanks.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  7. #57
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    List view
    Not sure if this is a bug or preference, but its been driveing me crazy.
    The scroll button in the list view allways start at the bottom of the list and also the list is sorted in alpha order but "A" is allways at the bottom of the list. Its just really weird for me to have to drag UP to scroll down and for some reason its really hard to actually grab the scroll button.
    Also, i checked and unchecked the "reverse scroll buttons (not slider)" option but it didnt seem to do anything. Im not really sure what that option is supposed to do anyway.
  8. #58
    Jan 2003
    Ruston, LA
    I have a bug to submit. The number pad will not work in the radio module if the region is set outside of the US. This will be fixed in 1.0.9 allowing you to set your own thousands seperator.
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  9. #59
    Jan 2002
    Long Island, NY
    Yeah, if you could reverse the order in which the list populates that would rock.
    HAha funny, your submitting bugs you found yourself.
  10. #60
    Apr 2000
    Little Rock, Arkansas
    Hey frodo...
    Just wondering if you ever found out anything about that strange problem I'm having with my playlists in that they are in a bizarre order on the playlist screen? Here is a repost of the pictures before... not sure that you coudl really recreate it, especially since no one else seems to have mentioned it on theirs, just wondering if you have any thoughts on how I can correct it on my end?
    btw, Im fully updated to 1.08
    The Grand aMP3 Project
    Car: 96 Pontiac Grand Am
    Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
  1. Bug Reports
    By frodobaggins in forum PV Bugs
    Last Post: 02-17-2005, 01:01 AM
  2. Official Bug reports.
    By skippy76 in forum V.O.I.C.E.S
    Last Post: 11-08-2004, 12:37 PM
  3. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 05:32 PM
  4. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
