Isn't there a option to use the built in fm radio player or use a external program like radiator?Originally Posted by Joeweb
If you use external there is a option to run FrodoPlayer in Mini mode.
ob1,
Frodo HAS changed the direction of the scroll bar, as was mentioned in the Transparancy thread.
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
I want to use the built in frodo fm radio control, but there is no mini icon. (so if i want to lisen to FM and to open say the GPS, you have to stop the FM to go back to the main frodo window and the launch the GPS.) If i'm playing a MP3 I can just mini frodo and keep lisening to the music. But you can't do that in the FM screen.
Dont use full screen. Set the resolution in the Frodo INI file to be 800x575 in the Advanced Screen Settings section. Then the task bar is awlays visible.
Don't Fear The Gurkey
Click here to check out My Setup
Originally Posted by wkolodny
Yep! That did the trick!!! Thanks a lot.![]()
Still... a "mini-radio" part of frodoplayer would be usefull...
-Mars
Good Point.Originally Posted by Marsupial
Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
Will FrodoPlayer be integrating Destinator anytime soon? It seems to have most of the other things I want....
Send me a GPS and software.Originally Posted by kiztope
Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
