Page 1 of 10 12345678910 LastLast
Results 1 to 10 of 92
Thread: OLD Feature Requests
    Jan 2003
    Ruston, LA
    Lightbulb OLD Feature Requests
    1. Author: LESLIEx317537
    --A) Reverse scroll bar.
    --B) Mouse scroll wheel support for playlist or volume change
    --C) Play DVD on AutoInsert
    --D) Mouse disapear on DVD Play
    --E) Remember text scroll direction in Mini-Mode
    --F) Safe Volume resume abort on external change of volume
    FrodoBaggins Comment:
    --A) Not possible
    --B) Will Investigate
    --C) Implimented
    --D) Will Consider
    --E) Implimented
    --F) Implimented
    2. Author: Confused
    --A) Built in support for ir remote (irman)
    --B) Built in Destinator for GPS
    --A) Will Investigate
    3. Author: leenas
    --A) Single button Mini-Mode with Expand Action
    --B) Multiple Directory Browse/Search
    --A) Will Consider
    --B) Will Consider
    4. Author: gospeed.racer
    --A) Gamma control
    --B) Disabling everything but VIS/VID Mode
    --C) Automatically through settings configure as windows shell
    --D) Assign a default action to exit
    --E) Remove unused buttons from Shutdown Menu
    --A) Does not work on all video cards. Use external for now.
    --B) Added option to Jump to Vis/Vid on play
    --C) Dangerous, will not impliment for your own good. Do it manually.
    --D) Will consider
    --E) This is accomplished through skinning.
    5. Author: Naamanf
    --A) Volume always start at 100%
    --A) Will Consider
    6. Author: MikeH
    --A) Fade between songs
    --A) Not possible
    7. Author: xtreamvette
    --A) Minimize Vis/Video on click
    --A) Dependent on Video Card
    8. Author: Izik
    --A) In mini-mode, text scroll reverse
    --B) In full mode, text scroll for the "visual" area
    --C) Different display options for playlist, ie: <Title> - <Artist>
    --D) Option to not allow full screen visualization
    --E) Editable extension list
    --F) Disable Tooltips
    --A) Click on it. Also will now remember setting.
    --B) Will Consider
    --C) Implimented 3 modes
    --D) Implimented
    --E) Working on it
    --F) Working on it
    9. Author: Marsupial
    --A) Day/Night Skin Changer
    --B) Security Features for Setup (Password)
    --C) ID3Tag Editor
    --D) Disable Album art completely
    --E) Scratchpad/Notetaker
    --A) Implimented
    --B) Will Do
    --C) Will Consider - Likely
    --D) Implimented
    --E) Will Consider - Later
    10. Author: chut
    --A) Scroll buttons in lists
    --A) Implimented in 1.0.5 Pending
    11. Author: wkolodny
    --A) Minimize button
    --B) Temperature monitor
    --A) Will Consider
    --B) Will Consider - Later
    12. Author: Kenzu
    --A) Keyboard control with arrows/remote
    13. Author: ddogg_777
    --A) Brightness adjust for Videos
    --A) Not Possible
    14. Author: STI_FFY
    --B) Equalizer
    --A) Not Possible
    15. Author: reda4
    --A) Mouse actions on release instead of click
    --A) Will Consider
    16. Author: veetid
    --A) Built-in MapPoint GPS
    --B) Stretched Skins 800x600 Widescreen
    --B) If I have time, until then, bug other skinners
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jun 2002
    Malaysia
    What about our request here? =)
    1.0.5 not too long from now
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    /me is impressed.
    Also: thanks to actually hear us and implement those that fast. Believe me its appreciated.
    -Mars
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    I believe i asked about this before, but for the life of me i cant remember what your answer was or find the thread where i asked it. Anyway, here goes.
    1.) Option to assign seperate buttons to each mode instead of mode fwd /mode back
    2.)Vis/ album art to be added as a mode
    3.) keyboard shortcuts to have more than one key, ie Ctrl-Alt-G as a keyboard shortcut
    below are some feature request from above that i would also like too.
    5A
    6A (i know, just thought id second the motion)
    11A
    15A (make it an option)
    16A (any skin i make will be widescreen)
    liq
    Jan 2003
    Ruston, LA
    Quote Originally Posted by liquid_smoke
    5A
    11A
    liq
    1. No
    2. No
    3. Planned
    As for:
    5A - In 1.0.5
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    Only a few suggestions for the software:
    A}Is there a chance you can make it so you can edit what browsing options frodoplayer uses.
    I never browse my media by artist or genre or albumn, and it's a hassle to arrow over to browse by folder. All i'm asking is for an option to disable/enable the different ways individually.
    B} an option to disable mp3 id3 tags and just have it display the file name.
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    Aug 2003
    Chicago
    this is more of a question, but if its not already supported then i guess its a feature request.
    can any of the items have transparency?
    Jan 2003
    Ruston, LA
    I am trying to make my lists transparent. But as they are not standard controls
    I have to do a little more work. This is the only planned transparency and I
    do not guarantee I can pull it off.
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Aug 2003
    Chicago
    sweet, I hope you can pull it off
    Aug 2003
    Chicago
    Speaking of the list
    Is there a way currently to format the text more. I want to increase the distance between each line of text to be farther apart so i dont click on the wrong line by accident. Look at media engine for an example of what im talking about.
  1. Lilliput mirror image feature.
    By Dluvr22 in forum LCD/Display
    Last Post: 03-09-2004, 05:42 AM
  2. Replies: 15
    Last Post: 03-07-2004, 11:23 AM
  3. My car has been photographed today to feature in total car audio!
    By bertybassett in forum General MP3Car Discussion
    Last Post: 02-13-2004, 01:03 PM
  4. anybody actually use radio feature?
    By Mikesz in forum ME Archive
    Last Post: 05-17-2003, 11:08 PM
  5. new feature for LCD plugin
    By grandamp3 in forum Software & Software Development
    Last Post: 04-26-2000, 02:22 PM
