Results 1 to 8 of 8
Thread: line in support?
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    line in support?
    I dont know if if its just me (maybe) but how do you get frodoplayer to open your line in? I tried clicking on the XM button but it dosent do anything. I have it set to lin in in the settings. Am i missing something?
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    That could be somehow great - having audio control over the aux. in. of the computer to avoid getting more and more fancy devices when you are cheap.
    and no I think it is not intended so far to be that way.
    -Mars
    Jan 2003
    Ruston, LA
    I don't understand. I assume you mean FM, because right now XM is just an app launcher.
    The options in the FM tab is what the volume controls adjust in radio mode.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Aug 2003
    Chicago
    FM seems to be an app launcher too. What i want to do is open my line in to listen to my XM radio. I dont have the pc version, i have the car version but i have it hooked up to the line in on the pc because my HU only has one AUX.
    A while ago (frodo) you wrote me a program that toggles my line in and wave (linewavetoggle.exe), i just want a good way to have that function inside frodoplayer, maybe as a mode?
    For now i set it up as an external app, but havent tried it out yet. But adding it as a mode would be easier to get to it.
    Jan 2003
    Ruston, LA
    Quote Originally Posted by liquid_smoke
    No, FM can be an app launcher, but the top where it says "path to radiator" is exactly that, the path to radiator.
    FM can either use the built in radio function(tied to radiator) or launch an external application.
    I may add the ability in settings to bring up some sliders and muteboxes for the common volume controls.
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Feb 2004
    Montreal
    is there a way to simply get into "mute, enable Line-IN" mode with volume control of some sort... some kind of AUX system...?
    -Mars
    Aug 2003
    Chicago
    just an update,
    frodo I used your linewavetoggle.exe app as the external app for XM and FM and it works great. Dont know why i didnt try this sooner. It even works better with frodoplayer than as a stand alone because frodoplayer pauses the mp3 when it runs the app
    Jan 2003
    Ruston, LA
    just an update,
    Forward thinking my man
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. Hooking up amp question REM line
    By Jake in forum General Hardware Discussion
    Last Post: 02-09-2007, 03:19 PM
  2. line noise
    By sq_geek in forum General Hardware Discussion
    Last Post: 07-09-2006, 08:48 PM
  3. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 11:44 AM
  4. Easy way to mute/unmute line in ?
    By liquid_smoke in forum General Hardware Discussion
    Last Post: 12-31-2003, 02:02 AM
  5. When will ME support plug-in???
    By vbi in forum ME Archive
    Last Post: 10-31-2003, 07:39 AM
