Results 1 to 7 of 7
Thread: reda4's MMI skin in multiple colours :)
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Talking reda4's MMI skin in multiple colours :)
    Having downloaded and tried out reda4's skin for FrodoPlayer, I found a couple of niggling problems, those namely being that each screen is a different colour, and also that the volume buttons in the radio are round the wrong way!!
    So, i've compiled all the screens to the same colour, so there are now 4 seperate zip files for each colour, and I've also fixed the radio volume buttons
    Update 09/06/2004: All screens are now DONE, and the links below are updated with the complete files
    Update 06/09/2004 20:10GMT
    Zip files are updated yet again. I am about to release my External Destinator control program for use with FrodoPlayer, and therefore the mini-mode of FrodoPlayer required modification for this purpose.
    Within the zip files are the following files which will require editing before use:
    MiniDefault.ini
    MiniGPS.ini
    SkinDefault.ini
    SkinGPS.ini
    Skins\MiniDefault\
    Skins\MiniGPS\
    Depending on whether you require to use the standard mini-mode, or whether you will be using the Destinator program (GPS), you will need to rename the relevent files/directories to Skin.ini and Skins\Mini\
    If these files are NOT renamed, FrodoPlayer WILL NOT work properly.
    Download links:
    Zip files are available at the following locations (and they also all contain the required fonts for the skin):
    Blue
    Green
    Orange
    Red
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    yeah.. I too liked the skin, but didnt like the many colours it came in.. hats off to u m8.. and thanks to reda4 for the original
    CdR
    Aug 2003
    Essex, England
    I've now done the OSK and mini-mode (apart from the bug which I have notified Frodo about, once he fixes that the mini-mode will be fine) and am in the process of doing the DVD mode buttons, once those are done I will update the above zip files with these fixes (currently the zip files do not contain these fixes)
    Garry
    www.aimee.cc
    Aug 2003
    Essex, England
    OK, everything is done, and updated files have been uploaded.
    I hope this is of some use to anyone
    Garry
    www.aimee.cc
    Mar 2004
    Det, MI
    Link to skin files does'nt seam to work.
    Aug 2003
    Essex, England
    Quote Originally Posted by Joeweb
    Don't know what's up with your end, but it works fine from here. (Here being at work behind firewall etc)
    Garry
    www.aimee.cc
    Aug 2003
    Essex, England
    MiniDefault.ini
    MiniGPS.ini
    SkinDefault.ini
    SkinGPS.ini
    Skins\MiniDefault\
    Skins\MiniGPS\
    Garry
    www.aimee.cc
  1. Laguna Skin
    By CdRsKuLL in forum MediaCar
    Last Post: 06-20-2004, 09:27 AM
  2. finnaly skin uploaded
    By liquid_smoke in forum ME Archive
    Last Post: 12-31-2003, 10:13 PM
