Thanks for taking the time to do this. I will test it out later.
Well, here it is. Hopefully it will be useful and wont be flamed too bad, hehe.
Anyways, right now it only has configurations to do the main skin.ini, but with custom box in the program and editing the ini by hand you could do the rest of the skins with just editing the name you need.
Includes:
-supports .jpg, .bmp, gif files
-export to ini
-save to .fro format
-load .fro format
-resize boxs
heres some caps
-Resizing
-Select type of box
-Configure fonts, colors, options
-Select color
So heres the first version, I wanted to get something out, future version will allow you to do all the different types of ini needed by frodoplayer.
Please report to me any bugs you find or anything.
And of coarse, you can grab it here hehe
FrodoSkinner v1.0
[H]4 Life
I'm a lesbian too.
I am for hire!
frodo- I'll post on the web site
Go ahead, WebmasterOriginally Posted by vcbb5
[H]4 Life
I'm a lesbian too.
I am for hire!
lol
First off, great app, save a ton of time.
Just a few little issues ive found while testing it out last night.
App seems to slowdown everything else on my system while its open. The app itself is fast and responsive, but everything else on the system slows to a crawl while its open. I have Dual Procs and 1GB of ram w Geforce4 just for reference.
When i save out the .ini file it seems to write some of the info into the file twice. Like if i set all the buttons to the function i want, save out the .ini file, then change what some of the buttons do and resave out the .ini file it writes the new info at the bottom of the file but dosent remove the previous data.
Should there be two file menus? one is attatched to the main window of the app and only says 'file" the other one is a floater that has more options and also the exit app button on the far right, the other main window has no exit,minimize buttons.
Other than that, great app and makes things a lot easier. Thanks a bunch for making this.
Thanks for using and for the reply with bugs.Originally Posted by liquid_smoke
About the about slowing the system dow, Im noticing that too. Ill have to look into it to see whats hogging the cpu time.
The ini file writing twice, I know exactly whats happening with the way you described the problem. Its not overwritting the file its just appending to the end. I will fix this ASAP.
Yea, when i was initially designing the program i thought id have two windows, but now I see its not necessary so Im planning on making it one window.
Thanks again for the comments and usage!
Hmm I cant seem to recreate the exporting out once than again and it just adds it to the bottom.
When you say "set all the buttons to the function i want, save out the .ini file, then change what some of the buttons do"
what are you doing when you change some of the buttons or mean by this? Currently you can only resize once a button is made and cannot change its type or options.
Ok, heres a quick update...
Hopefully fixed two bugs. Thanks to liquid_smoke for reporting.
v1.1
-Fixed Bug: Caused CPU usage to increase to 99%
-Fixed Bug: No longer can overwrite project by selecting New when a project is already open
FrodoSkinner v1.1
