Page 16 of 18 FirstFirst ... 6789101112131415161718 LastLast
Results 151 to 160 of 172
Thread: FP Feature Requests
  1. #151
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    Quote Originally Posted by frodobaggins
    You don't read the forum much in here do you ?
  2. #152
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    I had some additional thoughts the other day.
    While playing a song, if you single clink on another song, when the currently playing song is finished, it will skip to the song after the one selected. What I would like to see is that it plays the song you have selected (not theone after it) when the playing song is finished. It is a small change, but I think it makes sense to play the selected song, if it is not the song that has just finished.
    You already said that you plan to have a true shuffle in the next version, what would you think about actually showing the shuffled playlist in the window, instead of jumping around the list like the current implementation.
    This isn't really a new request, just a suggestion of how to implement what I mentioned before
    I would also like to be able to use the main music player interface to build a playlist.
    You would select build a new playlist, and give it a name, then it would pop you back to the main music screen, where you can play music as normal (selecting by playlist, artist, etc). or using the search feature to search for all the songs with 'unk' in the name. There is an additional button added to the interface, which allows you to add all the songs in the current window to the playlist.
    This is kinda like the favorites playlist building in media car, but you can add multiple songs at one time, and you can change the playlist you are adding to.
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
  3. #153
    Quote Originally Posted by zPilott
    one click to play
    that's what I suggested too
    also
    TV surport can be simplly added by using russion software
    FLY2000TV
    because it surport background control by sending message....
    skin would be some like DVD interface...
    FLY 2000 TV v2.38 Windows messages
    Examples:
    HWND fly2kWnd = FindWindow ("TMain", "ZolotarevFly2000TV");
    - for send message to main panel
    HWND fly2kVWnd = FindWindow ("TVideoFrame", "Video window");
    - for send message to video window
    Exit -
    PostMessage(fly2kWnd, WMFLY_EXIT, NULL, NULL);
    or
    PostMessage(fly2kWnd, WM_CLOSE, NULL,NULL);
    Set main volume Up -
    PostMessage(fly2kWnd, WMFLY_VOLUMEUP, NULL, NULL);
    Set main volume Down -
    PostMessage(fly2kWnd, WMFLY_VOLUMEDOWN, NULL, NULL);
    Set Brightness Up -
    PostMessage(fly2kWnd, WMFLY_CHANGEMODEVOL, NULL, NULL); // select brightness
    PostMessage(fly2kWnd, WMFLY_VOLUMEUP, NULL, NULL); // increase brighthess
    Set mute/unmute trigger -
    PostMessage(fly2kWnd, WMFLY_MUTEUNMUTE, NULL, NULL);
    Start/Stop avi capture -
    PostMessage(fly2kWnd, RUNSTOPCAPAVI, NULL, NULL);
    Switch channel Up -
    PostMessage(fly2kWnd, WMFLY_CHANNELUP, NULL, NULL);
    Switch channel Down -
    PostMessage(fly2kWnd, WMFLY_CHANNELDOWN, NULL, NULL);
    Switch to channel 8 -
    PostMessage(fly2kWnd, WMFLY_CHANNEL8, NULL, NULL);
    #ifndef __FLY2000TVMSG_H__
    #define __FLY2000TVMSG_H__
    #define WMFLY_HIDEV WM_USER+325 // Show/Hide Video window
    #define WMFLY_HIDEP WM_USER+326 // Show/Hide Main panel
    #define WMFLY_SHOWA WM_USER+327 // Show Main panel and Video window
    #define WMFLY_CHANNELUP WM_USER+328 // Switch channel Up
    #define WMFLY_CHANNELDOWN WM_USER+329 // Switch channel Down
    #define WMFLY_CHANNEL0 WM_USER+330 // Switch to channel number 0
    #define WMFLY_CHANNEL1 WM_USER+331 // Switch to channel number 1
    #define WMFLY_CHANNEL2 WM_USER+332 // Switch to channel number 2
    #define WMFLY_CHANNEL3 WM_USER+333 // Switch to channel number 3
    #define WMFLY_CHANNEL4 WM_USER+334 // Switch to channel number 4
    #define WMFLY_CHANNEL5 WM_USER+335 // Switch to channel number 5
    #define WMFLY_CHANNEL6 WM_USER+336 // Switch to channel number 6
    #define WMFLY_CHANNEL7 WM_USER+337 // Switch to channel number 7
    #define WMFLY_CHANNEL8 WM_USER+338 // Switch to channel number 8
    #define WMFLY_CHANNEL9 WM_USER+339 // Switch to channel number 9
    #define WMFLY_CHANGEMODEVOL WM_USER+340 // Change mode volume (Brightness, Contrast, Hue, Saturation, Sharpness, Gain)
    #define WMFLY_VOLUMEUP WM_USER+341 // Set volume up for mode, selected by mode volume
    #define WMFLY_VOLUMEDOWN WM_USER+342 // Set volume down for mode, selected by mode volume
    #define WMFLY_MUTEUNMUTE WM_USER+343 // Set Mute/UnMute trigger
    #define WMFLY_SHANGESOURCE WM_USER+344 // Change source (TV, FM, Composite, S-Video)
    #define WMFLY_FULLSCREEN WM_USER+345 // Set FullScreen/Window mode
    #define WMFLY_TELETEXTONOFF WM_USER+346 // Set On/Off Teletext mode
    #define WMFLY_ONTOPV WM_USER+347 // Set On/Off Stay-OnTop mode for Video window
    #define WMFLY_ONTOPP WM_USER+348 // Set On/Off Stay-OnTop mode for Main panel
    #define WMFLY_RESETVIDEO WM_USER+349 // Reset Video amplifier volume to default
    #define WMFLY_RUNSTOPCAPAVI WM_USER+350 // Start/Stop avi capture
    #define WMFLY_RUNSTOPCAPMPG WM_USER+351 // Start/Stop mpeg capture
    #define WMFLY_RUNSTOPCAPWAV WM_USER+352 // Start/Stop wav capture
    #define WMFLY_MAKESNAP WM_USER+353 // Make Snapshot
    #define WMFLY_RUNSTOPMSNAP WM_USER+354 // Start/Stop Multi-Snapshot
    #define WMFLY_INFINITYLOOP WM_USER+355 // Infinity Loop On/Off
    #define WMFLY_CHSURFONOFF WM_USER+356 // Channel Surfing Start/Stop
    #define WMFLY_CHGETINFO WM_USER+357 // Get current channel's info
    #define WMFLY_RECALL WM_USER+358 // Recall previous channel
    #define WMFLY_SETSLEEP WM_USER+359 // Set sleep timer
    #define WMFLY_REMOTEON WM_USER+360 // Remote Control ON
    #define WMFLY_REMOTEOFF WM_USER+361 // Remote Control OFF
    #define WMFLY_FSCRTIME WM_USER+362 // Show/Hide Time in Fullscreen mode
    #define WMFLY_SHANGETVFM WM_USER+363 // Switch TV/FM
    #define WMFLY_UNROLL WM_USER+364 // Roll/UnRoll Main Panel
    #define WMFLY_PAUSE WM_USER+365 // Pause/Continue Video Preview
    #define WMFLY_PAUSEREC WM_USER+366 // Pause/Continue any Recording
    #define WMFLY_TVGUIDE WM_USER+367 // Show current TVGuide program
    #define WMFLY_NUMBMODE WM_USER+368 // Change channel's number select mode
    #define WMFLY_A2_CHNL WM_USER+369 // Change A2 SAP and NICAM M1/M2 audio channel
    #define WMFLY_OTRLIMIT WM_USER+375 // Instant Record Limit Time (OTR)
    #define WMFLY_SLEEP WM_USER+370 // Suspend to tray
    #define WMFLY_WAKEUP WM_USER+371 // Wake Up from tray
    #define WMFLY_EXIT WM_USER+372 // Exit program
    #define WMFLY_SLEEPWAKE WM_USER+373 // Suspend to tray/Wake Up trigger
    #endif
  4. #154
    Aug 2004
    Germany
    I'm not sure if I missed something but I couldn't find anything about it...
    The APPS-skin is seperate and you can't select different skins for day and night. Could you add an option to FrodoPlayer to select seperate apps-skins for day and night ? Or better: make it possible to put the APPS-skin in the skin folder so you can create individual apps-skins for each skin ?
  5. #155
    Jan 2003
    Ruston, LA
    Quote Originally Posted by Konrad
    I haven't had much chance to work on the apps skin portion. I will begin working
    on that after next version.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  6. #156
    Low Bitrate fireball106's Avatar
    Jul 2004
    Israel
    Refresh rate for volume label
    Frodo, how about increasing the refresh-rate for the volume label?
    I just ordered a Griffin PowerMate, so it leads me to the thought - I'll be controlling windows' mixer volume level!
    It seems like the volume level is updaing every second exactly, could you please make it faster? something like 5-10 times a second. It shouldn't overload the CPU as most of the times the event wouldn't need to update the GUI, so it's just a simple check.
    What d'ya say?
    Lior "Fireball"
  7. #157
    Jan 2003
    Ruston, LA
    Quote Originally Posted by fireball106
    What d'ya say?
    Is this REALLY a problem ? I know I adjust the volume according to my ears,
    not what some GUI tells me.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  8. #158
    Jul 2004
    Israel
    Of course I usually adjust by listening, but it is important to have some visual indication!
    Now, if I want to adjust to 80% level exactly, I have to do it very slowly. This isn't SOOO bad, yet it is very annoying
    I'm sure many other users will agree with me.
    Think about it this way - I never saw a headunit with slow indication for volume level. Actually, I never even saw a software with this kind of slow indication, these are the kind of controls that should be updated in almost-realtime.
    Com'on... It's just another VB event / timer =]
    Lior "Fireball"
  9. #159
    Jul 2004
    In regards to the volume refresh rate, it is mildly annoying. I say if it is a very simple thing to do, then it would be a nice update. If it requires tonnes of coding, then bollocks to it.
  10. #160
    Jan 2003
    Ruston, LA
    fireball106 and Jackboot: Check the FP 1.09 status report.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. Feature Requests
    By frodobaggins in forum PowerVoice
    Last Post: 02-20-2006, 03:03 AM
  2. Basic install Instructions for new FP user
    By eazyrog in forum FrodoPlayer
    Last Post: 10-13-2004, 06:04 PM
  3. Two new (hopefully) feature requests
    By therussman2002 in forum FrodoPlayer
    Last Post: 08-10-2004, 03:01 PM
  4. Humble thoughts about FP...
    By technopsych in forum FrodoPlayer
    Last Post: 07-13-2004, 12:58 AM
  5. OLD Feature Requests
    By frodobaggins in forum FrodoPlayer
    Last Post: 06-12-2004, 03:21 PM
