Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: I'm just stupid! Still can't get album art to work.
  1. #11
    Low Bitrate NorthGaVigor's Avatar
    Tenneessee
    www.natchezss.com
    God Bless America and Our President!
  2. #12
    Aug 2003
    Houston, Texas
    Quote Originally Posted by frodobaggins
    it must be literally "album.jpg"
    ah okay! I get it now! literally the file is called album.jpg where album is not a variable to the name of the album! thanks!
  3. #13
    Aug 2003
    Houston, Texas
    Quote Originally Posted by NorthGaVigor
    Yeah I just modified mine to reflect
    still didn't work... The image I'm using is 124x74 and I changed the skin in FrodoPlayer to 1024x768 and that still didn't fix it either.
    There's nothing found in the fperrorlog1.txt or the fperrorlog2.txt.
    And I tried un-installing FrodoPlayer, made sure the FrodoPlayer directory under program files was removed and re-installed it. That didn't help. If you figure it out, let me know!
  4. #14
    Tenneessee
    Still nothing for me also. Has anyone been able to display artwork in FrodPlayer?
    Thanks guys.
    www.natchezss.com
  5. #15
    Jan 2003
    Ruston, LA
    This is what i did:
    Created folder called "Media" on "C:"
    Put 1 mp3 file inside and 1 "album.jpg" file inside.
    Changed database inside FrodoPlayer to "C:/media".
    Still same result.
    See attached
    I see you don't have it where you can see file extensions. I bet the extension
    on that is jpeg not jpg
    It needs to be jpg
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  6. #16
    Constant Bitrate STI_FFY's Avatar
    New Market, MD
    What the...
    I can't seem to get this to work either.
    My Album Art was fetched off the web by Windows Media Player. The files are using complex names, there are three of them (one large, one small for resizing - and a third with a simpler but still "incorrect" name). All of these have the "hidden" attribute set and I can't seem to clear it.
    I can rename any of them to the proper spec for Frodoplayer to access it (Album.jpg), but still no go.
    Is it maybe because they are "hidden"?? How does one remove this attribute?
    SeeYa! -Jim-
  7. #17
    New Market, MD
    Eureka!!
    Hey, guys I figured it out. It is because WinMediaPlayer saves the files as "systems" and "hidden". You have to clear these attributes.
    Use the command prompt (if you have win XP), point it at the root of your music files (in my case I entered d: at the prompt to go to that drive, then cd to music).
    Once there, issue the command:
    attrib /s -s -h *.jpg
    ...and it will run through them and change all the jpg files to not be system or hidden files.
    Then you just have to rename them.
    Hey-Frodo, any chance you could change it to use album art name as specified in the options? Or go with the MS standard "Albumart.jpg" ?
    Oops - edit -
    The filename that is there by default is "AlbumArtSmall.jpg". If Frodoplayer looked for that name it would work once the attributes were cleared.
    SeeYa! -Jim-
  8. #18
    Jan 2003
    Ruston, LA
    Quote Originally Posted by STI_FFY
    Oops - edit -
    The next version you will be able to specify what name you want it to look for.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  9. #19
    New Market, MD
    Cool... thanks.
    I found a powerful batch renamer that's free, in case anyone wants to make it work as it is coded now. Right-click and "save-as" this link.
    Bulk Rename Utility
    SeeYa! -Jim-
  10. #20
    Tenneessee
    Thanks for your help guys. That fixed it! See i told you it would be simple. I never thought of that!
    www.natchezss.com
  1. Ripping to MP3 WITH album art?
    By coachreed in forum General MP3Car Discussion
    Last Post: 05-20-2004, 07:19 AM
  2. album cover art ?
    By hotwater9 in forum ME Archive
    Last Post: 01-05-2003, 04:28 AM
  3. Album Art in XP
    By C4M in forum General MP3Car Discussion
    Last Post: 06-26-2002, 12:35 PM
  4. DVD and CD burner dont work above win 98
    By Mikesz in forum General Hardware Discussion
    Last Post: 02-09-2002, 08:56 PM
  5. Which remote to work with IRMAN
    By percyt2k in forum General Hardware Discussion
    Last Post: 05-26-2001, 04:08 PM
