XMPCR has hibernation problems?
I decided to start a new thread instead of hijacking Frodo's plea for XMPCR layout suggestions....
The XMPCR appears to have trouble coming out of hibernation. This is a shame because everything else (FP, RadioXtreme, and Routis) wakes up just fine. If I don't MANUALLY shut down XMPCR before going into hibernation, I have to unplug/replug the USB connection before it will start working again. Majoe PITA.
I found this over at XMFAN.com.
Quote:
It looks like hibernate closes the USB port.
The software does not know what to do and crashes.
So it looks like unless you run some sort of powerd hub.
It will not work when the computer goes into hibernation.
Can any of you software guys figure out a solution for this?
