Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: line in mute..
    FLAC djmickyg's Avatar
    Feb 2004
    line in mute..
    i have a small request...
    can u make in the shortcut menu.. a shortcut for muting the line in volume and pausing/stoping the music..
    i'll be running a tv tunner into the line in and want to be able to swutch the sound of and on..
    thanks
    mick
    Jan 2003
    Ruston, LA
    You can do this yourself.
    You just need to open frodoplayer ini.
    Choose 1 of the 7 extra buttons and assign an app to it.
    Luckily for you, I already coded an app for this, lemme look it up.
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jan 2003
    Ruston, LA
    Newer version at bottom
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Feb 2004
    dam.. what havent u thought off..
    i'll try that out now.
    thanks
    Variable Bitrate wkolodny's Avatar
    DC
    Quote Originally Posted by frodobaggins
    That is sweet frodo. Any chance you have one that will mute the mic in too? My pc doesnt have line in.
    Don't Fear The Gurkey
    Click here to check out My Setup
    Jan 2003
    Ruston, LA
    Quote Originally Posted by wkolodny
    No, but I can make one.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    DC
    As a member of the monkey clan, I would be eternally in your debt.
    Thanks.
    Feb 2004
    am i doing this right?
    i have the file unziped into the main root dir of frodoplayer
    and in the ini i have put
    APP1MINI=TRUE
    APP1COMMANDLINE=LineToggle.exe
    APP1PAUSE=true
    its works, but should there be an icon put in the app square?
    and can i set a short cut key for this??
    thanks
    Feb 2004
    ow i have a problem..
    it does mute the line in again when i go back to the full screen out of mini mode and start playing mp3's
    Jan 2003
    Ruston, LA
    Quote Originally Posted by djmickyg
    APP1MINI=TRUE
    APP1PAUSE=true
    thanks
    You'll have to set up an icon yourself.
    Yes, in the settings you can set a shortcut key.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. Hooking up amp question REM line
    By Jake in forum General Hardware Discussion
    Last Post: 02-09-2007, 03:19 PM
  2. line noise
    By sq_geek in forum General Hardware Discussion
    Last Post: 07-09-2006, 08:48 PM
  3. Question on Line Out of M10000 and Audigy NX
    By Mears in forum General Hardware Discussion
    Last Post: 06-10-2004, 05:00 AM
  4. Line Noise Reduction: Suggestion
    By VanMan69 in forum Car Audio
    Last Post: 06-08-2004, 12:47 AM
  5. Easy way to mute/unmute line in ?
    By liquid_smoke in forum General Hardware Discussion
    Last Post: 12-31-2003, 02:02 AM
