I'm looking
Frodo,
I'm having trouble launching XM from within FP. I've put the path of the app (C:\Program Files\XM Satellite Radio\XMMT.exe) in "path" and copied the command line options from the desktop shortcut and entered them. When I try to launch XM from FP nothing happens. When I remove the command line options, XM attempts to start but hangs at the startup window. When I launch from the desktop shortcut, everything works fine. Any thoughts of what I might be doing wrong?
Thx
MikeH
I'm looking
[H]4 Life
I'm a lesbian too.
I am for hire!
This is an error on my part. A hotfix in a few minutes.
[H]4 Life
I'm a lesbian too.
I am for hire!
For now you will need to use LMF:
LMF 1.1 Released
Your LMF.INI should look like:
[MAIN]
COMMANDLINE=C:\Program Files\XM Satellite Radio\XMMT.exe
COMMANDLINEOPTIONS=127.0.0.1 /q /s /r2d2
UNLOAD=TRUE
Then tell FrodoPlayer to launch LMF.
I will fix this problem in 1.09.
Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
this works......thx
MikeH
No problem, I'm glad you found this so I could fix the problem.Originally Posted by MikeH
[H]4 Life
I'm a lesbian too.
I am for hire!
I guess I'm a little surprised that no one else has had this problem. Are folks not launcing XM from FP?
MikeH
Actually this would affect all apps with commandline options, I can'tOriginally Posted by MikeH
believe this hasn't come up yet.
Especially since it happens with the other frontends and is the
reason I wrote LMF in the first place !
Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
