Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: Volume changes to 100% when skipping songs???
  1. #11
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    so i tested it out with your default skin and it still keeps doing it. The only thing that may be different is that i am using the digital S/PDIF port from my M10000. I don't know if that makes any difference i still have the problem. Do you have any other suggestions. I would like to controll the volume mainly with the touch screen (your software) but am forced (which isn't so bad) to use my surround sound control unit.
  2. #12
    Jan 2003
    Ruston, LA
    Quote Originally Posted by antimatter
    Try windows media player and see what happens.
    I can guarantee it's not a bug in my program.
    There is NO volume code in those functions.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  3. #13
    Jan 2004
    California
    Okay. I will try it at lunch today and post after lunch. The only difference i can see (besides the fact that frodoplayer rocks) is that the WMP does't map the volume change to the WAV. Thats the only time that i have a problem. When it is mapped to the master volume it doesn't change the volume at all.
    FOOOBAR
  4. #14
    Jan 2003
    Ruston, LA
    FOOOBAR
    Okay so let me get this straight.
    You are playing a song, the volume is at X%.
    You hit next. The volume goes to 100% ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  5. #15
    Jan 2004
    California
    Yea that is correct...
  6. #16
    Jan 2004
    California
    Okay... I tested it with WMP and it seems to be working correctly in WMP. When i skip songs the volume stays the same although i don't know what volume the slider is controlling (master or WAV)
    Any other suggestions guru monkey man?
  7. #17
    Jul 2004
    NL, Druten
    are you just using frodoplayer or do you have another program in the back?
    I experienced the same problem with frodoplayer and Alturion.
    In Aturion you have to set a volume level.. say i use 40%
    when i play a song the volume get up to 40% even when i volume up/down.
    I finally got it solved by installing another soundcard (SB live!) don't ask me why or how, but my problems are over..
  8. #18
    Jan 2004
    California
    What is Alturion?
    Unfortunatly i am using a VIA EPIA M10k onboard Sound card (S/PDIF port to be precice) I will see if there are any other hidden services running in the background
  9. #19
    Jan 2004
    California
    uhhhhh..... any other help here? I am at a loss. I sware frodoplayer is bumping the volume to 100% whenever i select a new song by double clicking on it or skipping tracks. I understand that there is no code relating to volume in those functions but somthing is making it jump up to 100%. When i use Windows Media Player everything works as it should and also winamp.
    Frodo I am not asking for an immediate answer but could you please look into this.
    If anyone else out there has a Via EPIA m10000 and is using the S/PDIF port to an external Digital surorund processor and is running frodoplayer please let us know if you have this problem?
    And why doesn't the master volume work to control S/PDIF?
    Arggggggg
    Thanks frodo
  10. #20
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    Arggggggg
    Thanks frodo
    The S/PDIF port is outputting a datastream not analog signal. Thats why master volume does not work. There is no flag for parsing external volume level info either. For more info regarding S/PDIF read
    this.
    What happens to you is quite strange. Have you tried to put the newest Vinyl audio drivers for your M10K? ( Link here )
    You do have directx 9.0b, don't you?
  1. Sound Volume Issues
    By ether in forum Media Engine
    Last Post: 08-02-2004, 01:24 PM
  2. Suggestions / Requests
    By LESLIEx317537 in forum FrodoPlayer
    Last Post: 07-29-2004, 01:23 AM
  3. Official requests thread.
    By skippy76 in forum V.O.I.C.E.S
    Last Post: 06-03-2004, 03:56 AM
  4. Replies: 11
    Last Post: 02-11-2004, 11:59 AM
  5. Replies: 6
    Last Post: 11-12-2003, 10:57 PM
