Results 11 to 20 of 22
Thread: Startup/Shutdown Movies?
  1. #11
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by frodobaggins
    How do you think FrodoPlayer resumes playback after hibernate ?....
    The same way every other program continues when coming out of hibernation... That isn't something that has to be programmed in the application. Having it play a short movie when starting up or hibernating would be different. Definitely possible though.
    Installed.
    -GPSSecure- - GPS Tracking
  2. #12
    Jan 2003
    Ruston, LA
    Quote Originally Posted by brady
    No.
    I detect hibernation. Stop music/video/dvd/etc. Do some processes.
    On resume, I start it all back up, programatically.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  3. #13
    Sep 2003
    Vic. Australia
    I haven't used frodoplayer (as I'm using a character LCD), but if frodo was to build in a menu option (if it doesn't already exist) to hibernate the system, upon this option being selected the software could write a flag to the registry to say it is going into hibernation, it should then be possible to check this flag and play the startup movie. Don't know if it would work, plus frodo would have to program it in.
  4. #14
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    This little app , Small App: WinampHelper , could with a litle help from startfox, run a file on hibernate/standby/resume instead of shutdown / restart winamp.
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
  5. #15
    Mar 2004
    So basicly you could put an option for frodoplayer for startup and shutdown movies..
    I think also that it would be cool...
    People could choose to see or not to see such movies.
    My startup time is so bad that couple of seconds doesn't matter anymore
    Nobody liked my monkey :(
  6. #16
    Jan 2003
    Ruston, LA
    Quote Originally Posted by JanneZ
    So basicky you could put an option for frodoplayer for startup and shutdown movies..
    I will not do that though.
    However, I always planned on allowing a script/program to run on return from hibernate. I guess I could throw that in and you could do what you want with it.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  7. #17
    Mar 2004
    Well that sounds great too..
    And how about script/program run when entering hibernate?
  8. #18
    Jan 2003
    Ruston, LA
    I could do that. BUT if it causes problems, the you are on your own.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  9. #19
    Variable Bitrate cheerio's Avatar
    Jun 2004
    San Antonio
    It would not cause problems as long as your program is coded correctly. You could simply tell windows not to shut down untill AFTER your program has terminated.
    http://msdn.microsoft.com/library/de...ermgt_tips.asp
    Read that for supporting power events.
  10. #20
    Jan 2003
    Ruston, LA
    Quote Originally Posted by cheerio
    I'm not talking about my prog causing problems.
    I'm talking about whatever they launch causing problems.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. seperate directroes for mp3 and movies?
    By paradoxni in forum Media Engine
    Last Post: 07-15-2004, 02:22 PM
  2. Playing DVD movies without the disc
    By Lumpyone in forum Software & Software Development
    Last Post: 12-18-2003, 10:19 AM
  3. OPUS startup/shutdown controller problem...
    By rbarr110 in forum Power Supplies
    Last Post: 11-15-2003, 12:38 AM
  4. Online movies for $1US
    By magnetik in forum Off Topic
    Last Post: 02-20-2002, 08:37 AM
  5. copying dvd movies?
    By kardas in forum Off Topic
    Last Post: 01-11-2002, 09:50 AM
