Results 1 to 6 of 6
Thread: Task switching with external apps/Contour Express config
    Newbie Swell Guy's Avatar
    Jun 2004
    Santa Clara Valley, California
    Question Task switching with external apps/Contour Express config
    How do you return to your music display once you enter an external app? Copilot for example. How do you switch back? Is there a hot key or hot area on the display to task switch?
    Is there a hot key to select an artist (or album) other than a select using the TS? I use Contour Express and have programmed hot keys. I'd like a select key so I can navigate tracks using jog shuttle. In fact, if anyone has this input device, how do you program for Frodo? I have "return" programmed on mine for select which works fine in MediaEngine.
    Thanks in advance.
    ~Swell Guy~
    Via Epia MII10000 .5 Gb memory, 60 Gb HD, Xenarc 7" TS, inverter power (for now)
    Jun 2004
    Wow, you can't task switch in FrodoPlayer? Maybe I'll look at my other options.
    Thanks, guys.
    ~Swell Guy~
    Jan 2003
    Ruston, LA
    Uh, dude. When you launched the app you had the option of putting frodoplayer in Mini-Mode. And the next version has a built in task switching function that replaces alt-tab.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jun 2004
    Quote Originally Posted by frodobaggins
    Where is this option? In the config panels, or am I queried (I don't see this one)? I guess I can program an alt-tab into my Contour. Why don't you just put a touch button that does that?
    How 'bout a key for selecting an artist to jump to the song selection window without using the TS?
    Thanks, Frodo. Any docs yet that I can refer to in the future?
    ~Swell Guy~
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    When you setup which external app to use for your GPS and DVD player there is a switch to fill in to "minimize" when starting external app. When you want to go back to the music player, press the downward facing arrow on the left side of your display. Had me confused too!
    Quote Originally Posted by Swell Guy
    Stop Buying New Music CD's.
    Hit The RIAA where it lives.
    Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
    Jun 2004
    Quote Originally Posted by chut
    Yeah, it's in the config panel. Thanks, works great. Thanks you guys.
    No one uses a Contour I guess?
    ~Swell Guy~
