Page 1 of 31 1234567891011 ... LastLast
Results 1 to 10 of 305
Thread: FP 1.09 Status Report
    Jan 2003
    Ruston, LA
    New full screen mode 100%
    --Playlist access in full screen.
    --Status Bar in full screen.
    --Menu in full screen.
    --Position bar in full screen.
    --Will not minimize from full screen when video changes.
    All sliders/scroll bars independent now
    Fine tuning of Info screen now available
    Transparency on lists for main page(except fullscreen playlist)
    Transparency for list "place holders" (IE the labels "All Audio, CD, etc")
    Extra Labels added (Optional)
    --Currently Playing Track
    --Extra Duration
    --Bitrate
    Task Switcher - 100%
    Scrolling Info in Info Visualization Mode
    --With options to run off individually
    Visual indicator of counter when objects require
    time to hold them down.
    Button to get in and out of full screen mode.
    Also you can hold down for 2 counts on vis.
    New mini mode now complete.
    You guys will love it
    Phone Control Interoperability 100%
    Mini-Mode now works with Main(Music & Video) , XM, and FM
    Interlock Device for Video/Visualization. (100%)
    Random/Shuffle Play Improved
    --Will not play same song twice unless you play all
    ----songs first or refresh or do it manually
    --Keeps record of what has been played
    ----meaning you can back up or roll forward what you've played
    Windows Messages for Remote Control & Status Messages (100%)
    --This should help a lot of people until plugins are supported.
    Frodo Can Also Now be controlled remotely over the network. (50%)
    (UDP Control)
    ---(With Feedback if you map a port)
    FrodoWebServer Integrated (100%)
    ---(Server parts completed 100%)
    ---Can Serve Files, Web Pages, Applications
    ---Integrated Command Set for 99% FrodoPlayer Control
    ------Selectable Return Types, 2 types of html, xml, dump
    ---CGI Support
    ---FPWebins (Web Plugin support)
    -----Persistant and Non-Persistant objects (Persistant can be graphical )
    --------Interface your own objects, html syntax(GET, POST)
    New Settings Menu
    New Sort Options
    ---Track Number, etc
    XM PCR Support
    New Browse Modes 100%
    ---Browse By Album Art
    ---Browse By Directory (New Version)
    ------ (Skinnable, Easy to Use)
    Modifier Keys for Key Press Control 100%
    ---CTRL, ALT, SHIFT
    DVD Position Remembering (Planned to add) 0%
    FrodoCam Integration with optional remote trigger (100%)
    Secret Program Embedded 100%
    ---You guys will love it
    [Probably not gonna make it]
    ------->FrodoBrowser - 10% (Might not make it in this ver )
    ------->FrodoWeather (With smart caching) 50%
    [/Probably not gonna make it]
    More Bug Fixes
    Extra Volume Function (Volume Mode 2) which will bring
    --volume up or down a user defined %. (.1% - 100%)
    Volume Ramp for Volume Mode 1 now user definable. (.1% - 100%)
    Volume Update Function moved to it's own timer/routine.
    User configurable update rate from every (.1 seconds to 2 seconds)
    Volume Button Speed now user configurable. (.01 seconds to .2 seconds)
    15 new (OPTIONAL!) buttons added to the skin:
    11 Modes, 4 VisModes
    MiniMode now works with DVD.
    Finished all the keyboard shortcuts (I think)
    Finished the minimize buttons for XM & FM.
    Run command on resume from Standby/Hibernate 100%
    I had to add an extra settings menu.
    CD Eject/Close Added.
    Filtering of ID3 Tags is now optional.
    --This *should* allow you unicode
    --guys to see your stuff right
    --but I make no promises
    Windows Messages Now Complete (I think)
    UNC Paths seem to be working fine.
    Can hide mouse globally.
    Hide mouse on dvd.
    Run command on FrodoPlayer startup 100%
    Playlist display options:
    --> Artist - Title
    --> Title - Artist
    --> Title
    --> Filename
    Can now disable all modes except:
    --> All Music
    --> All Video
    FrodoPictures integrated 100%
    DVD Player will remember position on exit of last playing dvd.
    16 Sort Order Options
    Optional Menu Behavior:
    --> Start opened.
    --> Return to menu from functions.
    --> Stay open until clicked.
    Now can specify the default filename to look for album art.
    --> Other supported modes still apply
    I will update this post and bump the thread on updates.
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jan 2003
    Ruston, LA
    I screwed the last thread up.
    Here is the latest update:
    Update:
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    very cool, i am very much looking forward to trying it. yours is the only front end I use now and I like it very much.
    Stop Buying New Music CD's.
    Hit The RIAA where it lives.
    Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    I think we should keep this thread really clean for Frodo. Let him do the posting.
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Jan 2004
    NYC
    frodo will it be possible in 1.09 to have the playing mp3 song info displayed on the main menu -when you go back from thhe mp3 player screen to main menu screen
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    I hope you are not rendering the software too heavy... remember some people will be running fp on slower machines.
    Question - how does the windows communication thinggy works? that is intended with Girder, right?
    because as soon as you have girder compatible intercommunication, I will use this as an HTPC as well in the living room
    Everythign seams REALLY cool.
    question/suggestion: I know you already have password protected config. Can the password protection be used also for going to mini-mode and for closing/shutting down/exiting?
    it would be to avoid people from using outside software from the computer. (more embedded-style) Of course, all those could be configurable and most likely have the same password.
    Erm... I have a skin ongoing - will I have to change it when you release the new version?
    if so, tell me I will delay my skining.
    -Mars
    FLAC chut's Avatar
    Jul 2003
    I think if thats what he wants he will request that. I didn't notice if that is what he did. And I think that kind of distorts the reason these forums exist. The free and easy exchange of ideas and technique. where all can contribute. er...off topic....but maybe we should let the author of the thread decide what he wants in it? Anyway, thanks for the update and thanks again for the fantastic software!
    Quote Originally Posted by EBFoxbat
    Jan 2003
    Ruston, LA
    You guys can post all you want in here, just try to stay on topic.
    If the thread gets too cluttered I will start a new one. I tried to
    clean the other but I screwed up So I just deleted it
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    FLAC chut's Avatar
    Jul 2003
    sooo...uh...when do you think you might relaese 1.09?
    I might be able to help with an FTP server...I just put one up.
    Low Bitrate Bryan Pape's Avatar
    Quote Originally Posted by chut
    Frodo still hasn't emailed you your beta-test copy?
    Gosh...
    I mean..... the rest of us got ours.....
    Seriously though, I think you're about as anxious as I am. I've been checking back daily and nightly, but I'm trying not to ask the "when" question. I'm sure that Frodo wants it just right, rather than to release something buggy or "mostly done" - especially with all the anticipation.
    I'm personally looking forward to seeing XM and Zorro's Phone Control integrated into the same environment as my MP3's, which will really make this an awesome front end!!!
    Thanks for all your hard work Frodo!!
    Bryan
  1. Just downloaded FP 1.09 and have a question...
    By ddogg_777 in forum FrodoPlayer
    Last Post: 10-09-2004, 04:26 AM
  2. FP 1.09 Screenshots Thread...
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-04-2004, 04:23 PM
  3. Minimizing FP
    By asci01 in forum FrodoPlayer
    Last Post: 09-12-2004, 01:43 AM
  4. FP 1.09 ? maybe should be 1.1.0
    By DaveDog in forum FrodoPlayer
    Last Post: 07-14-2004, 09:34 PM
  5. Humble thoughts about FP...
    By technopsych in forum FrodoPlayer
    Last Post: 07-13-2004, 12:58 AM
