Results 1 to 10 of 12
Thread: why do pictures distort/lose res in frodoplayer
    Aug 2004
    Nebraska
    I have a good setup in PS with my skin so far. The only thing is when I preview it all in frodoplayer everything is pixalted and has no where near the quality of what I was looking for. The skin I'm making is for the 800x600. Yes I turned my screen to 800x600 for testing. Is this just a limitation with frodoplayer or what can I do in PS to make the images CLEAR in frodoplayer?
    2004 Nissan 350z Daytona Blue
    2x 10" IDMax D4
    1250.1 kicker amp
    crappy dell carputer
    Jan 2003
    Ruston, LA
    I've never had a problem with pictures distorting.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Aug 2004
    Germany
    Me neither.
    Aug 2004
    Nebraska
    any suggestions to fix it? Should i increase the DPI of the picture? I have it at 90 pixels per inch and all of my pictures that I have imported are of super high quality.
    2x 10" IDMax D4
    1250.1 kicker amp
    Low Bitrate fireball106's Avatar
    Jul 2004
    Israel
    Hey.
    I have no idea how inches/DPI are related. The only thing you should care about is the resolution, which is measured in Pixels.
    I think you may be using "USE_ADVANCED_SCREEN_SETTINGS", so FrodoPlayer resized your skin, and that distortion you see is called "aliasing".
    Check out this part which Frodo wrote from Manual/howto.txt :
    How to turn on/off advanced screen resolution control/placement.
    As well as how to configure.
    The advanced settings are defined in "frodoplayer.ini"
    Under the [MAIN] tag
    USE_ADVANCED_SCREEN_SETTINGS=True
    Under the [ADVANCED] tag
    ADV_TOP=212
    ADV_LEFT=200
    ADV_WIDTH=1024
    ADV_HEIGHT=768
    All measurements HERE are in pixels.
    Try setting
    USE_ADVANCED_SCREEN_SETTINGS=False
    and see if the problem will be solved
    P.S. Frodo - some antialiasing algorithm when resizing the skins could be a nice feature to have...
    Lior "Fireball"
    Aug 2004
    Nebraska
    It is set to false. I guess I'll play around with it some more when I get home.
    2x 10" IDMax D4
    1250.1 kicker amp
    Jul 2004
    Israel
    Quote Originally Posted by Carter
    If it is set to false, so you should have the same resolution in Windows and in the skin (e.g. 800x600 on both)
    Lior "Fireball"
    Aug 2004
    Nebraska
    Ok, anyone know what monitors normal DPI is for 800x600?
    2x 10" IDMax D4
    1250.1 kicker amp
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    afaik 75
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
    Jan 2003
    Ruston, LA
    If you are in photoshop, make the picture 800x600.
    Simple enough.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
  2. Replies: 63
    Last Post: 10-11-2004, 06:27 PM
  3. FrodoPlayer doesn't show main window
    By mportobello in forum FrodoPlayer
    Last Post: 08-18-2004, 05:32 PM
  4. Frodoplayer - Audiobooks & OBD-2?
    By fbruno in forum FrodoPlayer
    Last Post: 05-04-2004, 09:51 PM
  5. Frodoplayer and Girder
    By leenas in forum FrodoPlayer
    Last Post: 05-01-2004, 12:42 AM
