Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: iGuidance Embedded
  1. #11
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    Quote Originally Posted by Frodo
    Quote Originally Posted by d_sellers1
    The location can be changed be editing the .INI file. I redirected to iGuide.exe (the program that hits OKAY for you) and it works fine.
    No need for that as FrodoPlayer will click it for you.
    I don't recommend using the iGuide.exe. As Frodo explained, FP now handles that for you. If you run iGuidance via the iGuide.exe it will automatically bring up the menu which you will have to manually close before being able to see the map. Could be useful, though, if you always punch up a destination... Direct to the real iGuidance.exe.
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
  2. #12
    Low Bitrate phord's Avatar
    May 2004
    Quote Originally Posted by frodobaggins
    Zoinks! Not on mine. iGuidance 2.0 and FP 1.09 take 3. When I click on Navigation I get the OK box and Frodo acts like nothing loaded. I click OK and it pops up non-embedded. If I switch back to Frodo, then click Navigation again, it gets embedded.
    Love the iGuidance integration, but I do wish the OK box would get clicked for me!
    Should I put this in the Bugs thread?
    Carputer-II: Infiniti Q45
    Simple setup, NAV-only
    Tablet PC :: FP :: iGuidance
    Status: Ghetto, baby!
    Carputer-I: '99 Honda Odyssey
    Dual monitor, separate outputs: Finished
    FP :: iGuidance :: WinDVD :: EPIA M-10000 :: Opus 150w :: In-dash/On-dash
  3. #13
    Illinois
    Quote Originally Posted by phord
    have the same problem. the first time i bring it up I need to hit ok and it is not embedded. If i then maxmize frodo and click gps again, it is embedded
  4. #14
    Variable Bitrate NRGZ28's Avatar
    Oct 2004
    Las Vegas
    I think you need to have the "external GPS" option NOT checked for Iguidance to embed properly. I have that problem now after I messed with the settings. It used to embed and click Ok just fine
    K301 7" Motorized Screen
    Mini SLIMPRO SP625 Cappucino PC
    RoadRunner / IGuidance 3.0
    Pioneer 7700MP HU
    MTX 1500D 1500 Watt Sub Amp
    2 x 12" MTX 8000 subs
    1998 Olds Aurora 4.0 V8
  5. #15
    Oct 2004
    Las Vegas
    Unhappy
    Nevermind... I guess that option doesn't matter. It still won't embed right... weird
    Pioneer 7700MP HU
  6. #16
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Is there also a way to reconnect the GPS w/out having to hit the reconnect button after resuming from hibernation?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  7. #17
    Low Bitrate ImInSanDiego's Avatar
    Oct 2003
    Isn't it obvious
    Load iGuidance at startup
    I was having problems with Frodo embedding properly, but I noticed that if I open Iguidance manually (and don't press 'OK' button) and then press GPS in FP, the embedding works perfectly. So I simply put the Iguidance shortcut in the startup folder so that it will be ready to run when I press GPS. No problems anymore.
  8. #18
    Jan 2003
    Ruston, LA
    I'm gonna redo the code in Take 4. It's just some timing issues.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  9. #19
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    I'm not having any issues. iGuidance embeded properly, I don't have to push any "ok" button, and it resumes from hybernate 90% of the time.
    I'm green at this, but can I send someone a log file or something to help?
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  1. IGuidance 2.0... WOW
    By unsavory in forum GPS
    Last Post: 04-20-2005, 02:14 AM
  2. Launching iGuidance under Media Engine
    By StationRocket in forum GPS
    Last Post: 11-29-2004, 01:56 PM
  3. Embedded iGuidance Window Size?
    By All4Sky in forum MediaCar
    Last Post: 08-27-2004, 09:00 AM
  4. Switch between Frodo player and GPS (IGuidance)?
    By Nanozic in forum FrodoPlayer
    Last Post: 07-12-2004, 02:58 AM
  5. PowerMate on Windows XP Embedded
    By JasonSurratt in forum Input Devices
    Last Post: 01-14-2004, 12:06 PM
