That's a known issue to be fixed in 1.09.
Bug Reports post #70
- Z
I'm just skinning the mini mode of Feb's skin. I made a new skin based on Frodo's default skin (ini, proportions, button position, etc.) (see attached standartskin.gif).
Now that I made the fullmode button bigger I wanted to move the scrolltext to the right. TEXT_TITLE_LEFT shoul be the same as LABEL_TIME_LEFT. But when I want to move the scrolltext to the right a grey box appears (see my_skin_with_bug.gif).
I don't understand why this happens. I moved the repeat button out of the screen because I don't need it. I attached the ini of my skin.
Did I do something wrong or is this an error in FrodoPlayer ?
EDIT: Damn, may not attach the mini.ini. I attached the whole mini skin as zip
- Z
Thanks alot for your reply. Damn, now I'll have to wait for 1.09 to fix that
Just adjust your values until it works.
[H]4 Life
I'm a lesbian too.
I am for hire!
I already tried. No luck.
Try again![]()
[H]4 Life
I'm a lesbian too.
I am for hire!
You say that as if it's that easy. If I reduce TEXT_TITLE_LEFT the grey box gets smaller but it also moves the text box to the left so the text is above the fullmode button in my skin. If I increase TEXT_TITLE_LEFT the grey box gets bigger and the text box also moves to the right.
So I really don't see a workaround.
