Page 11 of 28 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 280
Thread: Bug Reports 1.09
  1. #101
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    I redefined the keys for next, previous, play, pause, stop and none of them work. Also if I press A (next) in the artist-album place then it skips the last album.
  2. #102
    Jan 2003
    Ruston, LA
    Quote Originally Posted by 0l33l
    You need to click the actual textbox for the shortcuts and see if any
    modifier keys are defined.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  3. #103
    Low Bitrate ImInSanDiego's Avatar
    Oct 2003
    Isn't it obvious
    Quote Originally Posted by frodobaggins
    I was thinking this was a bug as well, I didn't realize CTRL was checked.
    On another note, I think this is the first time I have posted in a long time. I've been watching the progress of the player and I'm very impressed with your work. I switched to Frodo from MediaCar when Coyote disappeared a while back. Thanks for your hard work!
  4. #104
    Variable Bitrate WeeZyFellA's Avatar
    Oct 2004
    New York
    with the patch installed, i still get the bbaa on the main menu after i start frodo, even after the i changed the .ini file to greater then 100 top and left
    am i doing something wrong
  5. #105
    Jan 2003
    Ruston, LA
    Quote Originally Posted by WeeZyFellA
    What did you change ? Whatever it was has nothing to do with that.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  6. #106
    Jan 2003
    Ruston, LA
    The BBAA appearing on the menu is a simple Z order issue. I will fix it for next patch.
    Workaround, don't start up fp in bbaa mode
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  7. #107
    Oct 2004
    New York
    i changed the skin.ini file and put the bbaa and bbd in and set them so i can click them, and it worked great, i got all the album to load, but when i took them out and set them to greater then 100 top and left and restarted fp, i left the directory on bbaa "click here to browse", that image was still there on the main menu on load.
    here is a pic of what im talking about
  8. #108
    Maximum Bitrate carpcnoobie's Avatar
    Mar 2004
    Is anybody else getting this?? It seems like it's ignoring my setting for elapsed time or remaining time. I'm actually getting both without any interventing. Sometimes countup, sometimes countdown. Haven't found any reason yet.
    Progress Meter:
    [|||||!||||'] 95% complete
    It's in... it's finally installed!!!! But never finished!
    "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
  9. #109
    Jan 2003
    Ruston, LA
    I already answered your question.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  10. #110
    Oct 2004
    New York
    looks like you did, thnx
    guess not to leave it in bbaa in the directory on start up
  1. Bug Reports
    By frodobaggins in forum PV Bugs
    Last Post: 02-17-2005, 01:01 AM
  2. Official Bug reports.
    By skippy76 in forum V.O.I.C.E.S
    Last Post: 11-08-2004, 12:37 PM
  3. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
  4. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 05:32 PM
