I probably should add that I am using WinAmp to view the tags. Is there a better way (maybe WinAmp is masking the problem somehow)?
Originally Posted by frodobaggins
They are. The tags look the same to me in the one file that works and the 13 that don't...
SeeYa! -Jim-
SeeYa! -Jim-
Winamp mixes version 1.x and 2.x tags.
I read both, but if a file has a version 2 tag, its the only
one that gets read. Make sure it is in the v2 tag.
[H]4 Life
I'm a lesbian too.
I am for hire!
Yep, it's in both. I just downloaded a free tag viewer, and it also shows both tags exactly the same. I don't see what the problem is.Originally Posted by frodobaggins
By the way, when are the tags read - only when building the DB? In other words if I change the tag do I have to reload the DB in order to display the new tag info?
SeeYa! -Jim-
yesOriginally Posted by STI_FFY
[H]4 Life
I'm a lesbian too.
I am for hire!
After playing around with FP for a while, setting filtering options and other settings, I close FP down. When I want to start again FP 'hangs'. I see the GUI, the DB directory structure flashes up and is then gone. The only way to start FP is to terminate through TM and reinstall FP.
here's the error logThanks17-10-2004 - 14:41:46 - 9 - Subscript out of range - frmWebServer-GetPersistantObjects - 0 - FrodoPlayer -
17-10-2004 - 14:41:46 - 8002 - Invalid port number - MainModule-LoadCamTrigger - 0 - MSComm -
17-10-2004 - 14:41:47 - 339 - Component 'RICHTX32.OCX' or one of its dependencies not correctly registered: a file is missing or invalid - frmDB-Form_Load - 0 - FrodoPlayer
Michael
edit:
this fixed my problem:
Originally Posted by javacool
"It does not understand, if it does not ride."
M10000, 512 Mb, 2,5" 40G, Slim DVD, Opus 90W, Xenarc 7", Leadtek 9532 GPS,
RoadRunner, MapMonkey, Pioneer HU, Pioneer 4 ch 400W, Kappa 6.5, Basslink X 200W
I cant get into settings 1, when i press the button it just goes back to the main fp screen
anyone have any ideas?
Originally Posted by jimmythecow
I get this too on my home PC. Win2000 SP4 - all prereqs installed.
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
im on XP sp 2
I think it is tagged right, unless Im missing something. This is a screen shot from Tag & Rename for one of the albums that is displaying 00 for the track numbers:Originally Posted by frodobaggins
'02 GTI
